Subject: |
Re: Fw: asynDriver - update record (timestamp), on no change |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Fri, 1 Mar 2019 16:46:15 +0100 |
Yes, Same as if you're setting MDEL=-1 in an analog record. This is not a reasonable default or suggested mode of operation, but in some cases exactly what is needed.
Does this mean that the records with unchanged data but new timestamps
will post monitors to subscribed clients on each 'update'? That would
potentially introduce a lot of unnecessary/unwanted CA traffic.
--- rod.
On 2/28/19 11:15 AM, Mark Rivers via Tech-talk wrote:
> ________________________________
> From: Mark Rivers
> Sent: Thursday, February 28, 2019 12:35 PM
> To: Joao Afonso
> Subject: Re: asynDriver - update record (timestamp), on no change
> Your proposed hack is indeed the workaround for now. It would be nice to add another way to do this, perhaps forceParamCallback(addr, param).
> Mark
> From: [email protected] <[email protected]> on behalf of Joao Afonso via Tech-talk <[email protected]>
> Sent: Thursday, February 28, 2019 11:16 AM
> To: [email protected]
> Subject: asynDriver - update record (timestamp), on no change
> Hello,
> I have an asyn driver IOC that periodically receives new data, updates the parameters (and timestamps), and runs the callbacks for the "I/O Intr" records.
> It has an extra thread that runs something like this:
> while(1)
> int value = wait_for_data();
> setIntegerParam(dev_addr, param_id, value)
> updateTimeStamp();
> callParamCallbacks(dev_addr);
> However, 'callParamCallbacks' will not update the record timestamp if the value received keeps being the same.
> From what I understand, this is the intended behaviour of asynDriver - no updates if data is the same -, but I would like to know if there a way to enforce it (to update the record timestamp)?
> One possible solution I think will work is to update the parameter with a random value first, to trigger the 'new data' flag, but it feels like an hack...
> Example:
> setIntegerParam(dev_addr, param_id, 0)
> Thank you,
> Joao Afonso
- Re: Fw: asynDriver - update record (timestamp), on no change Maren Purves via Tech-talk
- asynDriver - update record (timestamp), on no change Joao Afonso via Tech-talk
- Fw: asynDriver - update record (timestamp), on no change Mark Rivers via Tech-talk
- Re: Fw: asynDriver - update record (timestamp), on no change Rod Nussbaumer via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 01 Mar 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
