1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Fw: asynDriver - update record (timestamp), on no change
From: Maren Purves via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 1 Mar 2019 10:51:56 -1000
Example: we have some channels that shouldn't change (controlled
array temperatures come to mind) but we still need the fact that
they haven't changed updated and archived.
Maren
On 3/1/19 05:46, Ralph Lange via Tech-talk wrote:
Yes,
Same as if you're setting MDEL=-1 in an analog record.
This is not a reasonable default or suggested mode of operation, but in some cases exactly what is needed.
On Fri, 1 Mar 2019 at 15:18, Rod Nussbaumer via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
    Does this mean that the records with unchanged data but new timestamps
    will post monitors to subscribed clients on each 'update'? That would
    potentially introduce a lot of unnecessary/unwanted CA traffic.
         --- rod.
    On 2/28/19 11:15 AM, Mark Rivers via Tech-talk wrote:
     > ________________________________
     > From: Mark Rivers
     > Sent: Thursday, February 28, 2019 12:35 PM
     > To: Joao Afonso
     > Subject: Re: asynDriver - update record (timestamp), on no change
     > Your proposed hack is indeed the workaround for now.  It would be
    nice to add another way to do this, perhaps forceParamCallback(addr,
    param).
     > Mark
     > From: [email protected]
    <[email protected]
    <mailto:[email protected]>> on behalf of Joao Afonso via
     > Sent: Thursday, February 28, 2019 11:16 AM
     > To: [email protected] <mailto:[email protected]>
     > Subject: asynDriver - update record (timestamp), on no change
     > Hello,
     > I have an asyn driver IOC that periodically receives new data,
    updates the parameters (and timestamps), and runs the callbacks for
    the "I/O Intr" records.
     > It has an extra thread that runs something like this:
     > while(1)
     >      int value = wait_for_data();
     >      setIntegerParam(dev_addr, param_id, value)
     >      updateTimeStamp();
     >      callParamCallbacks(dev_addr);
     > However, 'callParamCallbacks' will not update the record
    timestamp if the value received keeps being the same.
     >  From what I understand, this is the intended behaviour of
    asynDriver - no updates if data is the same -, but I would like to
    know if there a way to enforce it (to update the record timestamp)?
     > One possible solution I think will work is to update the
    parameter with a random value first, to trigger the 'new data' flag,
    but it feels like an hack...
     > Example:
     > setIntegerParam(dev_addr, param_id, 0)
     > Thank you,
     > Joao Afonso
asynDriver - update record (timestamp), on no change Joao Afonso via Tech-talk
Fw: asynDriver - update record (timestamp), on no change Mark Rivers via Tech-talk
Re: Fw: asynDriver - update record (timestamp), on no change Rod Nussbaumer via Tech-talk
Re: Fw: asynDriver - update record (timestamp), on no change Ralph Lange via Tech-talk
Prev: Re: Fw: asynDriver - update record (timestamp), on no change Ralph Lange via Tech-talk
Next: Q: AD driver for Lucid Phoenix 5.0 MP camera Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 04 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
