1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: I'm looking for a pvacces example to read PVStructure
From: Marty Kraimer via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 12 Mar 2019 10:26:00 -0400
On 3/12/19 4:57 AM, will.rogers--- via Tech-talk wrote
From: [email protected] <[email protected]> on behalf of Heinz Junkes via Tech-talk <[email protected]>
Sent: 11 March 2019 16:41:54
To: tech-talk
Subject: I'm looking for a pvacces example to read PVStructure
I'm looking for a pva example c++ program which I can currently use (with Epics 7).
Unfortunately the examples I've found on the net don't work at all.
Above all, there seems to be a little confusion between PVAClient and pvac? (Or I don't get it)
I have a client that wants to read the PVStructure of a PV and then put new data  into
NTTable vector fields (x, y, z and time_index):
humma-kavula:~ junkes$ pvlist 0xB9EC6A5C00000000C2AFA421
CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
humma-kavula:~ junkes$ pvinfo CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
CHANNEL  : CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
STATE    : CONNECTED
ADDRESS  : 141.14.133.59:53379
epics:nt/NTTable:1.0
     string[] labels
     structure value
         double[] x
         double[] y
         double[] z
         int[] time_index
     string descriptor
     alarm_t alarm
         int severity
         int status
         string message
     time_t timeStamp
         long secondsPastEpoch
         int nanoseconds
         int userTag
     int counter
To read the PVStructure you can issue
pvget -r "" -v  CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
I do not know if any command line tool can change all the value fields with one command.
You could make the changes with the following set of commands:
pvput -r "value.x"  CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK x0 x1 ...
pvput -r "value.y"  CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK y0 y1 ...
pvput -r "value.z"  CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK z0 z1 ...
pvput -r "value.time_index"  CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK i0 i1 ...
You could create your own client code that uses channelPutGet to put all values and gets the entire structure.
Using pvaClientCPP your code would be something like:
   PvaClientChannelPtr channel = pva->channel("CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK");     PvaClientPutGetPtr putGet = channel->createPutGet("putField(value)getField()");
    putGet->connect();
    PvaClientPutDataPtr putData = putGet->getPutData();
    PVStructurePtr pvValue = putData->getPVStructure();
    // CODE TO  PUT ALL FIELDS IN value
    putGet->putGet();
    PvaClientGetDataPtr getData = putGet->getGetData();
    cout << getData->getPVStructure() << endl;
Marty
Re: I'm looking for a pvacces example to read PVStructure Heinz Junkes via Tech-talk
Re: I'm looking for a pvacces example to read PVStructure will.rogers--- via Tech-talk
Prev: ADPIcam driver question Jörn Dreyer via Tech-talk
Next: Re: I'm looking for a pvacces example to read PVStructure Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: I'm looking for a pvacces example to read PVStructure Mark Rivers via Tech-talk
ANJ, 13 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
