1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: I'm looking for a pvacces example to read PVStructure
To: 'Heinz Junkes' <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Mar 2019 17:25:58 +0000
I just built the master branch of exampleCPP with base 7.0.2 on linux-x86_64 with no warnings or errors.
corvette:base-7.0.2/modules/exampleCPP>git checkout master
Already on 'master'
corvette:base-7.0.2/modules/exampleCPP>make -sj clean
corvette:base-7.0.2/modules/exampleCPP>make –sj
From: [email protected] <[email protected]> On Behalf Of Heinz Junkes via Tech-talk
Sent: Tuesday, March 12, 2019 5:21 AM
To: [email protected]
Cc: [email protected]
Subject: Re: I'm looking for a pvacces example to read PVStructure
Hi Will,
thanks for looking it up. But I always seem to try the examples that don't work.
E.G. getputmonitor.cpp
In file included from ../getputmonitor.cpp:16:
/Users/junkes/ABER_JETZT/epics-base/include/pv/pvaClient.h:1736:10: warning: 'epics::pvaClient::PvaClientMonitor::monitorConnect' hides overloaded virtual function [-Woverloaded-virtual]
    void monitorConnect(
/Users/junkes/ABER_JETZT/epics-base/include/pv/pvaClient.h:1603:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::monitorConnect' declared here: type mismatch at 2nd parameter ('const epics::pvaClient::PvaClientMonitorPtr &' (aka 'const shared_ptr<epics::pvaClient::PvaClientMonitor> &') vs 'const epics::pvData::MonitorPtr &' (aka 'const shared_ptr<epics::pvAccess::Monitor> &'))
    virtual void monitorConnect(epics::pvData::Status const & status,
/Users/junkes/ABER_JETZT/epics-base/include/pv/pvaClient.h:1740:10: warning: 'epics::pvaClient::PvaClientMonitor::unlisten' hides overloaded virtual function [-Woverloaded-virtual]
    void unlisten(epics::pvData::MonitorPtr const & monitor);
/Users/junkes/ABER_JETZT/epics-base/include/pv/pvaClient.h:1616:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::unlisten' declared here: different number of parameters (0 vs 1)
    virtual void unlisten()
2 warnings generated.
c++ -o myEx  -L/Users/junkes/pvTest/lib/darwin-x86 -L/Users/junkes/ABER_JETZT/epics-base/lib/darwin-x86        -arch x86_64            myEx_registerRecordDeviceDriver.o getputmonitor.o    -lmyExSupport -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
Undefined symbols for architecture x86_64:
  "epics::pvaClient::PvaClientGet::issueConnect()", referenced from:
      ClientGetPutMonitor::channelStateChange(std::__1::shared_ptr<epics::pvaClient::PvaClientChannel> const&, bool) in getputmonitor.o
  "epics::pvaClient::PvaClientGet::setRequester(std::__1::shared_ptr<epics::pvaClient::PvaClientGetRequester> const&)", referenced from:
  "epics::pvaClient::PvaClientGet::get()", referenced from:
      ClientGetPutMonitor::get() in getputmonitor.o
  "epics::pvaClient::PvaClientGet::getData()", referenced from:
  "epics::pvaClient::PvaClientPut::issueConnect()", referenced from:
  "epics::pvaClient::PvaClientPut::setRequester(std::__1::shared_ptr<epics::pvaClient::PvaClientPutRequester> const&)", referenced from:
  "epics::pvaClient::PvaClientPut::getData()", referenced from:
      ClientGetPutMonitor::put(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) in getputmonitor.o
      ClientGetPutMonitor::getDone(epics::pvData::Status const&, std::__1::shared_ptr<epics::pvaClient::PvaClientPut> const&) in getputmonitor.o
  "epics::pvaClient::PvaClientPut::issuePut()", referenced from:
  "epics::pvaClient::PvaClientChannel::issueConnect()", referenced from:
      ClientGetPutMonitor::init(std::__1::shared_ptr<epics::pvaClient::PvaClient> const&) in getputmonitor.o
  "epics::pvaClient::PvaClientChannel::createMonitor(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
  "epics::pvaClient::PvaClientChannel::setStateChangeRequester(std::__1::shared_ptr<epics::pvaClient::PvaClientChannelStateChangeRequester> const&)", referenced from:
  "epics::pvaClient::PvaClientChannel::createGet(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
  "epics::pvaClient::PvaClientChannel::createPut(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
  "epics::pvaClient::PvaClientGetData::showChanged(std::__1::basic_ostream<char, std::__1::char_traits<char> >&)", referenced from:
  "epics::pvaClient::PvaClientGetData::getChangedBitSet()", referenced from:
  "epics::pvaClient::PvaClientMonitor::issueConnect()", referenced from:
  "epics::pvaClient::PvaClientMonitor::releaseEvent()", referenced from:
      ClientGetPutMonitor::event(std::__1::shared_ptr<epics::pvaClient::PvaClientMonitor> const&) in getputmonitor.o
  "epics::pvaClient::PvaClientMonitor::setRequester(std::__1::shared_ptr<epics::pvaClient::PvaClientMonitorRequester> const&)", referenced from:
  "epics::pvaClient::PvaClientMonitor::poll()", referenced from:
  "epics::pvaClient::PvaClientMonitor::stop()", referenced from:
      simple(char*) in getputmonitor.o
  "epics::pvaClient::PvaClientMonitor::start()", referenced from:
      ClientGetPutMonitor::monitorConnect(epics::pvData::Status const&, std::__1::shared_ptr<epics::pvaClient::PvaClientMonitor> const&, std::__1::shared_ptr<epics::pvData::Structure const> const&) in getputmonitor.o
      non-virtual thunk to ClientGetPutMonitor::monitorConnect(epics::pvData::Status const&, std::__1::shared_ptr<epics::pvaClient::PvaClientMonitor> const&, std::__1::shared_ptr<epics::pvData::Structure const> const&) in getputmonitor.o
  "epics::pvaClient::PvaClientMonitor::getData()", referenced from:
  "epics::pvaClient::PvaClientPutData::getPVStructure()", referenced from:
  "epics::pvaClient::PvaClientMonitorData::showChanged(std::__1::basic_ostream<char, std::__1::char_traits<char> >&)", referenced from:
  "epics::pvaClient::PvaClient::createChannel(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
  "epics::pvaClient::PvaClient::get(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [myEx] Error 1
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [src.install] Error 2
make: *** [myExApp.install] Error 2
On 12. Mar 2019, at 09:57, [email protected] wrote:
Hi Heinz,
I have recently tested some of the examples in https://github.com/epics-base/exampleCPP and they are working with EPICS 7.0.2.
Cheers,
Will
From: [email protected] <[email protected]> on behalf of Heinz Junkes via Tech-talk <[email protected]>
Sent: 11 March 2019 16:41:54
To: tech-talk
Subject: I'm looking for a pvacces example to read PVStructure
I'm looking for a pva example c++ program which I can currently use (with Epics 7).
Unfortunately the examples I've found on the net don't work at all.
Above all, there seems to be a little confusion between PVAClient and pvac? (Or I don't get it)
I have a client that wants to read the PVStructure of a PV and then put new data  into
NTTable vector fields (x, y, z and time_index):
humma-kavula:~ junkes$ pvlist 0xB9EC6A5C00000000C2AFA421
CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
humma-kavula:~ junkes$ pvinfo CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
CHANNEL  : CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
STATE    : CONNECTED
ADDRESS  : 141.14.133.59:53379
epics:nt/NTTable:1.0
   string[] labels
   structure value
       double[] x
       double[] y
       double[] z
       int[] time_index
   string descriptor
   alarm_t alarm
       int severity
       int status
       string message
   time_t timeStamp
       long secondsPastEpoch
       int nanoseconds
       int userTag
   int counter
I'm looking for a pvacces example to read PVStructure Heinz Junkes via Tech-talk
Re: I'm looking for a pvacces example to read PVStructure will.rogers--- via Tech-talk
Re: I'm looking for a pvacces example to read PVStructure Heinz Junkes via Tech-talk
Prev: Re: I'm looking for a pvacces example to read PVStructure Marty Kraimer via Tech-talk
Next: IOC for Brooks SLA series Luciano Carneiro Guedes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: I'm looking for a pvacces example to read PVStructure Marty Kraimer via Tech-talk
ANJ, 12 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
