1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: I'm looking for a pvacces example to read PVStructure
From: Marty Kraimer via Tech-talk <[email protected]>
To: Heinz Junkes <[email protected]>
Cc: [email protected]
Date: Thu, 14 Mar 2019 05:31:59 -0400
Change
int iChunk(char *pvName)
     PvaClientPtr pva= PvaClient::get("pva”);
try {
to
    PvaClient::setDebug(true);
 try {
What is the result?
Also what does:
pvget -v -r "" CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
show?
Marty
On 3/13/19 3:00 PM, Heinz Junkes wrote:
Hello, Marty,
Thanks for the example. But even with that I don't manage to run it.
#include <iostream>
#include <getopt.h>
#include <epicsThread.h>
#include <epicsTime.h>
#include <epicsExit.h>
#include <iocsh.h>
#include <iostream>
#include <pv/pvaClient.h>
#include <pv/pvData.h>
using namespace std;
using namespace epics::pvaClient;
using namespace epics::pvData;
try {
     PvaClientChannelPtr channel = pva->channel(pvName);
     PvaClientPutGetPtr putGet = channel->createPutGet("putField(value)getField()");
     putGet->connect();
     PvaClientPutDataPtr putData = putGet->getPutData();
     PVStructurePtr pvValue = putData->getPVStructure();
     // CODE TO  PUT ALL FIELDS IN value
     putGet->putGet();
     PvaClientGetDataPtr getData = putGet->getGetData();
     cout << getData->getPVStructure() << endl
     } catch (std::runtime_error e) {
         cout << "exception " << e.what() << endl;
         exit(1);
     return 0;
int main(int argc,char *argv[])
   epicsThreadId simpleId;
     if(argc>=2) {
         iocsh(argv[1]);
         epicsThreadSleep(.2);
     char pv[] = "CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK";
     simpleId = epicsThreadCreate("IChunkT", epicsThreadPriorityMedium,
                                 epicsThreadGetStackSize(epicsThreadStackMedium),
                                 (EPICSTHREADFUNC)iChunk, pv);
     iocsh(NULL);
     epicsExit(0);
     return(0);
The “ putGet->connect();” raises an exception
exception channel CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK PvaClientPutGet::connect
PvaClientPutGet::channelPutGetConnect)
pvRequest
structure
     structure getField
     structure putField
         structure value
error
Not Implemented
Error: epicsMutex::invalidMutex()
the PV is available
[junkes@dune iocmyEx]$ pvinfo CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK epics:nt/NTTable:1.0
     string[] labels
     structure value
         double[] x
         double[] y
         double[] z
         int[] time_index
     string descriptor
     alarm_t alarm
         int severity
         int status
         string message
     time_t timeStamp
         long secondsPastEpoch
         int nanoseconds
         int userTag
     int counter
Am I doing something wrong?
Danke, Heinz
Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
Faradayweg 4-6        |
D - 14195 Berlin        | E-Mail:        [email protected]
On 12. Mar 2019, at 15:26, Marty Kraimer via Tech-talk <[email protected]> wrote:
Using pvaClientCPP your code would be something like:
    PvaClientChannelPtr channel = pva->channel("CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK");
     putGet->connect();
     putGet->putGet();
     cout << getData->getPVStructure() << endl;
Re: I'm looking for a pvacces example to read PVStructure Marty Kraimer via Tech-talk
Re: I'm looking for a pvacces example to read PVStructure Heinz Junkes via Tech-talk
Re: I'm looking for a pvacces example to read PVStructure will.rogers--- via Tech-talk
Prev: RE: generalTime/epicsTimeGetCurrent and casr questions Mark Rivers via Tech-talk
Next: Re: I'm looking for a pvacces example to read PVStructure Marty Kraimer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: I'm looking for a pvacces example to read PVStructure Heinz Junkes via Tech-talk
ANJ, 14 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
