1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Inter-module dependency between stream and calc
From: "Konrad, Martin via Tech-talk" <[email protected]>
Date: Mon, 18 Mar 2019 16:15:13 +0000
I'm wondering how to handle dependencies between support modules the
right way (TM). Let's say I have the following chain of dependencies:
myIOC -> stream -> calc
Background: StreamDevice includes support for the sCalcRecord. Since I'm
building stream and calc as shared libraries that are shipped as
pre-canned Debian packages I want to build them with all their features
enabled.
The problem: myIOC does not make use of sCalcRecords so I only add the
following lines to its Makefile:
myioc_DBD += stream.dbd
myioc_LIBS += stream
The IOC builds fine but a careful look reveals that dbdExpand.pl prints
the following message:
"Device using undefined record type 'scalcout', place-holder created"
When I try to run the IOC it fails to load the DBD file:
dbLoadDatabase("../../dbd/myioc.dbd",0,0)
Declaration of recordtype(scalcout) preceeded full definition.
Error at or before "}" in file "../../dbd/myioc.dbd" line 5335
The relevant lines are:
5334 recordtype(scalcout) {
5335 }
5336 device(scalcout, INST_IO, devscalcoutStream, "stream")
I understand that the scalcout record not being defined anywhere is a
problem. So I use the following lines in the IOC's Makefile and
everything works as intended:
myioc_DBD += calc.dbd
myioc_LIBS += calc
However, I'm wondering if there is a way I can build stream without
forcing IOC engineers to include a DBD file they aren't using. In other
words: Is there a way to include the relevant calc stuff into stream.dbd
without causing problems on IOCs that are using calc directly?
Any help is appreciated,
Martin
P.S.: I'm using StreamDevice 2.8.8, calc 3.7.1 and Base 3.15.6.
Martin Konrad
High Performance Controls Team Leader
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: Inter-module dependency between stream and calc Ralph Lange via Tech-talk
Re: Inter-module dependency between stream and calc Zimoch Dirk (PSI) via Tech-talk
Prev: Re: StreamDevice processing issue Davis, Mark via Tech-talk
Next: Re: Inter-module dependency between stream and calc Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [no subject] VASU PADSUMBIA via Tech-talk
ANJ, 19 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
