I liked Ralph's idea to merge DBD files into one.
https://github.com/ralphlange/opcua/blob/master/devOpcuaSup/Makefile#L32
It turned out that I had reinvented wheel to build it with our own
building system, which is based on PSI. :)
Best,
Han
On 3/19/19 7:04 PM, Konrad, Martin via Tech-talk wrote:
All I think we need to allow that is for you to provide a separate
streamScalcout.dbd file that includes that device entry when the
build sees that CALC or SYNAPPS defined, and for that device() entry
to be excluded from the main stream.dbd file.
I actually tried that yesterday and it works fine for me. Please see the
attached patch. Dirk, I would appreciate if you could include this. Note
that I currently do not have plans to patch this into the Debian package
in case this doesn't make it into the official repo. I don't want the
Debian packaged version to use different DBD file names than the
upstream module (to avoid confusion).
Martin
- Inter-module dependency between stream and calc Konrad, Martin via Tech-talk
- Re: Inter-module dependency between stream and calc Zimoch Dirk (PSI) via Tech-talk
- Re: Inter-module dependency between stream and calc Konrad, Martin via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
