> All I think we need to allow that is for you to provide a separate
> streamScalcout.dbd file that includes that device entry when the
> build sees that CALC or SYNAPPS defined, and for that device() entry
> to be excluded from the main stream.dbd file.
I actually tried that yesterday and it works fine for me. Please see the
attached patch. Dirk, I would appreciate if you could include this. Note
that I currently do not have plans to patch this into the Debian package
in case this doesn't make it into the official repo. I don't want the
Debian packaged version to use different DBD file names than the
upstream module (to avoid confusion).
Martin
Martin Konrad
High Performance Controls Team Leader
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
From aa083278511d7046f3f4bedd76f1f19476767e4c Mon Sep 17 00:00:00 2001
Date: Mon, 18 Mar 2019 15:49:30 -0400
Subject: [PATCH] Create separate DBD files for use without CALC
This allows IOCs that don't use the StreamDevice support for
sCalcRecord to use StreamDevice without linking against the CALC
module.
Gbp-Pq: Name 0006-Create-separate-DBD-files-for-use-without-CALC.patch
src/Makefile | 34 +++++++++++++++++++++++++++++-----
1 file changed, 29 insertions(+), 5 deletions(-)
diff --git a/src/Makefile b/src/Makefile
index 0983d58..646f052 100644
--- a/src/Makefile
+++ b/src/Makefile
@@ -35,6 +35,10 @@ endif
LIBRARY_DEFAULT = stream
DBD += $(LIBRARY_DEFAULT).dbd
+DBD += $(LIBRARY_DEFAULT)-base.dbd
+ifdef CALC
+DBD += $(LIBRARY_DEFAULT)-scalcout.dbd
+endif
ifdef ASYN
LIB_LIBS += asyn
@@ -84,9 +88,29 @@ streamReferences: ../CONFIG_STREAM
$(PERL) ../makeref.pl Interface $(BUSSES) > $@
$(PERL) ../makeref.pl Converter $(FORMATS) >> $@
-# create stream.dbd from all RECORDTYPES
-$(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
- $(PERL) ../makedbd.pl $(if $(ASYN),--with-asyn) $(if $(BASE_3_14),,-3.13) $(RECORDTYPES) > $@
+# create stream-base.dbd from all RECORDTYPES except scalcout record
+$(COMMON_DIR)/$(LIBRARY_DEFAULT)-base.dbd: ../CONFIG_STREAM
+ $(PERL) ../makedbd.pl $(if $(ASYN),--with-asyn) $(if $(BASE_3_14),,-3.13) $(filter-out scalcout, $(RECORDTYPES)) > $@
+$(LIBRARY_DEFAULT)-base.dbd$(DEP): ../CONFIG_STREAM
+ echo $(LIBRARY_DEFAULT)-base.dbd: $< > $@
+STREAM_DBD_FILES = $(LIBRARY_DEFAULT)-base.dbd
+ifdef CALC
+# create stream-scalcout.dbd for scalcout record
+$(COMMON_DIR)/$(LIBRARY_DEFAULT)-scalcout.dbd: ../CONFIG_STREAM
+ $(PERL) ../makedbd.pl $(if $(ASYN),--with-asyn) $(if $(BASE_3_14),,-3.13) scalcout > $@
+$(LIBRARY_DEFAULT)-scalcout.dbd$(DEP): ../CONFIG_STREAM
+ echo $(LIBRARY_DEFAULT)-scalcout.dbd: $< > $@
+STREAM_DBD_FILES += $(LIBRARY_DEFAULT)-scalcout.dbd
+endif
+# create stream.dbd for all record types
+$(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: $(addprefix $(COMMON_DIR)/, $(STREAM_DBD_FILES))
+ cat $? > $@
-$(LIBRARY_DEFAULT).dbd$(DEP): ../CONFIG_STREAM
- echo $(LIBRARY_DEFAULT).dbd: $< > $@
+$(LIBRARY_DEFAULT).dbd$(DEP):
+ echo "$(LIBRARY_DEFAULT).dbd: $(STREAM_DBD_FILES)" > $@
2.19.1
- Re: Inter-module dependency between stream and calc Jeong Han Lee via Tech-talk
- Re: Inter-module dependency between stream and calc Zimoch Dirk (PSI) via Tech-talk
- Inter-module dependency between stream and calc Konrad, Martin via Tech-talk
Re: StreamDevice processing issue Davis, Mark via Tech-talk
<2019>
2025
2026
Re: Inter-module dependency between stream and calc Johnson, Andrew N. via Tech-talk
<2019>
2025
2026
