1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: dbdlint (dbd/db verify tool)
From: Sue Witherspoon via Tech-talk <[email protected]>
Date: Fri, 29 Mar 2019 19:35:00 +0000
Greetings!
  I am trying to upgrade to use EPICS 3.15.6 and my standard database make tool used to a database verification while converting a vdct vdb file. So the dbStaticHost.lib is gone. So I wanted to replace that functionality with Michael Davidsaver's dbdlint script.  So I got the code from github but I'm not able to communicate to the script my database definition.
devl06 [130]:   dbdlint -F -Wall /usr/dvlepics/epics/R3.15.6.J0/dbd/base.dbd junk.db
ERROR   junk.db:5 bad-rtyp - iocdevp4Apps:VMIc0979:C979_Chan05 has unknown record type ai
ERROR   Error processing junk.db
Traceback (most recent call last):
  File "/a/devsite/dvlepics/epics/modules/pypdb-master/pyPDB/dbdlint.py", line 121, in main
    walk(dbd, dbdtree, R)
  File "/a/devsite/dvlepics/epics/modules/pypdb-master/pyPDB/dbdlint.py", line 471, in walk
    fn(ent, results, I)
  File "/a/devsite/dvlepics/epics/modules/pypdb-master/pyPDB/dbdlint.py", line 245, in wholeRecInstField
    ftype = recent._fieldinfo.get(fname)
AttributeError: 'Block' object has no attribute '_fieldinfo'
ERROR   parent stack not empty at exit: [Block(record, ['ai', 'iocdevp4Apps:VMIc0979:C979_Chan05'], [Block(field, ['DTYP', 'Soft Channel'], None), Block(field, ['ASG', 'DEFAULT'], None), Block(field, ['ASLO', ''], None), Block(field, ['DESC', 'analog input record'], None), Block(field, ['DISS', 'NO_ALARM'], None), Block(field, ['EGU', 'volts'], None), Block(field, ['EGUF', '10.0'], None), Block(field, ['EGUL', '-10.0'], None), Block(field, ['EVNT', '0'], None), Block(field, ['HHSV', 'MAJOR'], None), Block(field, ['HIGH', '80.0'], None), Block(field, ['HIHI', '100.0'], None), Block(field, ['HOPR', '100.0'], None), Block(field, ['HSV', 'MINOR'], None), Block(field, ['LINR', 'LINEAR'], None), Block(field, ['LLSV', 'NO_ALARM'], None), Block(field, ['LOPR', '0.0'], None), Block(field, ['LSV', 'NO_ALARM'], None), Block(field, ['PHAS', '0'], None), Block(field, ['PINI', 'NO'], None), Block(field, ['PREC', '3'], None), Block(field, ['PRIO', 'LOW'], None), Block(field, ['SCAN', 'Passive'], None), Block(field, ['SIMS', 'NO_ALARM'], None)])]
Can someone give me a hint as to what I need to do get this to work?
junk.db is attached.
Thanks in advance,
Sue Witherspoon
Attachment: junk.db
Description: junk.db
Re: dbdlint (dbd/db verify tool) Johnson, Andrew N. via Tech-talk
Re: dbdlint (dbd/db verify tool) Michael Davidsaver via Tech-talk
Prev: Re: pvget is timing out Shen, Guobao via Tech-talk
Next: Re: dbdlint (dbd/db verify tool) Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ADpython issues with openCV sandeep-kumar.malu--- via Tech-talk
ANJ, 04 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
