On 3/29/19 12:35 PM, Sue Witherspoon via Tech-talk wrote:
> Greetings!
> I am trying to upgrade to use EPICS 3.15.6 and my standard database make tool used to a database verification while converting a vdct vdb file. So the dbStaticHost.lib is gone. So I wanted to replace that functionality with Michael Davidsaver's dbdlint script. So I got the code from github but I'm not able to communicate to the script my database definition.
> devl06 [130]: dbdlint -F -Wall /usr/dvlepics/epics/R3.15.6.J0/dbd/base.dbd junk.db
> ERROR junk.db:5 bad-rtyp - iocdevp4Apps:VMIc0979:C979_Chan05 has unknown record type ai
The python exception being shown below is actually a symptom this error.
I've pushed some updates which change this to:
> ERROR ../epics/base-git/dbd/base.dbd:5 incomplete-dbd - This tool must be run on an expanded .dbd. (eg. softIoc.dbd, not base.dbd)
which I hope should be clearer. dbdlint in full '-F' mode is meant to be run against an already
expanded .dbd file, such as would be loaded by an IOC.
I've also added a new warning -Wrec-append which which you may need to disable.
It trips when a record() appears a second time unless the recordtype is "*".
This was a Base 3.16 addition.
eg. "dbdlint -F -Wall -Wno-rec-append ...'
dbdlint also works with python3 now.
> ERROR Error processing junk.db
> Traceback (most recent call last):
> File "/a/devsite/dvlepics/epics/modules/pypdb-master/pyPDB/dbdlint.py", line 121, in main
> walk(dbd, dbdtree, R)
> File "/a/devsite/dvlepics/epics/modules/pypdb-master/pyPDB/dbdlint.py", line 471, in walk
> fn(ent, results, I)
> File "/a/devsite/dvlepics/epics/modules/pypdb-master/pyPDB/dbdlint.py", line 245, in wholeRecInstField
> ftype = recent._fieldinfo.get(fname)
> AttributeError: 'Block' object has no attribute '_fieldinfo'
> ERROR parent stack not empty at exit: [Block(record, ['ai', 'iocdevp4Apps:VMIc0979:C979_Chan05'], [Block(field, ['DTYP', 'Soft Channel'], None), Block(field, ['ASG', 'DEFAULT'], None), Block(field, ['ASLO', ''], None), Block(field, ['DESC', 'analog input record'], None), Block(field, ['DISS', 'NO_ALARM'], None), Block(field, ['EGU', 'volts'], None), Block(field, ['EGUF', '10.0'], None), Block(field, ['EGUL', '-10.0'], None), Block(field, ['EVNT', '0'], None), Block(field, ['HHSV', 'MAJOR'], None), Block(field, ['HIGH', '80.0'], None), Block(field, ['HIHI', '100.0'], None), Block(field, ['HOPR', '100.0'], None), Block(field, ['HSV', 'MINOR'], None), Block(field, ['LINR', 'LINEAR'], None), Block(field, ['LLSV', 'NO_ALARM'], None), Block(field, ['LOPR', '0.0'], None), Block(field, ['LSV', 'NO_ALARM'], None), Block(field, ['PHAS', '0'], None), Block(field, ['PINI', 'NO'], None), Block(field, ['PREC', '3'], None), Block(field, ['PRIO', 'LOW'], None), Block(field, ['SCAN',
> 'Passive'], None), Block(field, ['SIMS', 'NO_ALARM'], None)])]
> Can someone give me a hint as to what I need to do get this to work?
> junk.db is attached.
> Thanks in advance,
> Sue Witherspoon
- dbdlint (dbd/db verify tool) Sue Witherspoon via Tech-talk
Re: dbdlint (dbd/db verify tool) Johnson, Andrew N. via Tech-talk
Tech-talk Digest, Vol 13, Issue 150 peiyu Quan via Tech-talk
<2019>
2025
2026
Re: dbdlint (dbd/db verify tool) Michael Davidsaver via Tech-talk
<2019>
2025
2026
