1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: PvData , PvAccess, Confusion with different hardware architectures
From: Heinz Junkes via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 3 Apr 2019 18:39:18 +0200
On 2. Apr 2019, at 18:06, Michael Davidsaver <[email protected]> wrote:
Could you try replacing your client code with something based on the following?
#include <pv/pvData.h>
#include <pva/client.h>
namespace pvd = epics::pvData;
struct Example {
   pvac::ClientProvider ctxt;
   pvac::ClientChannel chan;
   Example()
       :ctxt("pva")
       ,chan(ctxt.connect("CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK"))
   void put(long val) {
       pvd::shared_vector<double> X, Y, Z, T;
       for(long i=0; i<100; i++)
           X.push_back(i);
           Y.push_back(i+1);
           Z.push_back(i+2);
           T.push_back(i+3);
       chan.put()
               .set("value.column0", pvd::freeze(X))
               .set("value.column1", pvd::freeze(Y))
               .set("value.column2", pvd::freeze(Z))
               .set("value.column3", pvd::freeze(T))
               .set("counter", val)
               .exec();
       std::cout<<chan.get();
This code can not be compiled:
/Users/junkes/RTEMS_POST_AUSTRALIA/RTEMS/rtems-5/bin/powerpc-rtems5-g++ -B/Users/junkes/RTEMS_POST_AUSTRALIA/RTEMS/rtems-5/powerpc-rtems5/beatnik/lib/ -specs bsp_specs -qrtems     -mcpu=7400                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall       -DRTEMS_HAS_ALTIVEC -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120     -I. -I../O.Common -I. -I. -I.. -I/export/epics/cry-test/include/compiler/gcc -I/export/epics/cry-test/include/os/RTEMS -I/export/epics/cry-test/include      -I/Users/junkes/ABER_JETZT/support/asyn/include   -I/Users/junkes/ABER_JETZT/support/devlib2/include -I/Users/junkes/ABER_JETZT/epics-base/include/compiler/gcc -I/Users/junkes/ABER_JETZT/epics-base/include/os/RTEMS -I/Users/junkes/ABER_JETZT/epics-base/include              -MM -MF Example.d  ../Example.cpp
/Users/junkes/RTEMS_POST_AUSTRALIA/RTEMS/rtems-5/bin/powerpc-rtems5-g++ -B/Users/junkes/RTEMS_POST_AUSTRALIA/RTEMS/rtems-5/powerpc-rtems5/beatnik/lib/ -specs bsp_specs -qrtems     -mcpu=7400                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall       -DRTEMS_HAS_ALTIVEC -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120     -I. -I../O.Common -I. -I. -I.. -I/export/epics/cry-test/include/compiler/gcc -I/export/epics/cry-test/include/os/RTEMS -I/export/epics/cry-test/include      -I/Users/junkes/ABER_JETZT/support/asyn/include   -I/Users/junkes/ABER_JETZT/support/devlib2/include -I/Users/junkes/ABER_JETZT/epics-base/include/compiler/gcc -I/Users/junkes/ABER_JETZT/epics-base/include/os/RTEMS -I/Users/junkes/ABER_JETZT/epics-base/include              -c ../Example.cpp
In file included from /Users/junkes/ABER_JETZT/epics-base/include/pv/pvData.h:22:0,
                 from ../Example.cpp:5:
/Users/junkes/ABER_JETZT/epics-base/include/pv/anyscalar.h: In instantiation of 'epics::pvData::AnyScalar::AnyScalar(T) [with T = long int]':
/Users/junkes/ABER_JETZT/epics-base/include/pva/client.h:492:41:   required from 'pvac::detail::PutBuilder& pvac::detail::PutBuilder::set(const string&, T, bool) [with T = long int; std::__cxx11::string = std::__cxx11::basic_string<char>]'
../Example.cpp:38:35:   required from here
/Users/junkes/ABER_JETZT/epics-base/include/pv/anyscalar.h:115:18: error: 'value' is not a member of 'epics::pvData::ScalarTypeID<long int>'
         _stype = (ScalarType)ScalarTypeID<TT>::value;
make[3]: *** [Example.o] Error 1
It’s because “long val”:
anyscalar.h:
        // this line fails to compile when type T can't be mapped to one of
        // the PVD scalar types.
call aExample
2019-04-03T07:35:41.411 Error binding socket 10.20.30.91:5076: Address already in use.
—> runtime Error
With the p4p server my client always crashed.
And changed from ScalarArrayPtr to typeArrayPtr’s
 if (ind < 3){
          PVDoubleArrayPtr pvDoubleArray = static_pointer_cast<PVDoubleArray>(pvField);
          cout << " pvDoubleArray len : " << pvDoubleArray->getLength() << "\n";
          pvDoubleArray->setLength(100);
          if (ind == 0) { pvDoubleArray->putFrom(x); cout << " put x \n"; }
          if (ind == 1) { pvDoubleArray->putFrom(y); cout << " put y \n"; }
          if (ind == 2) { pvDoubleArray->putFrom(z); cout << " put z \n"; }
          if (ind == 3) {
          PVIntArrayPtr pvIntArray = static_pointer_cast<PVIntArray>(pvField);
                cout << " pvIntArray len : " << pvIntArray->getLength() << "\n";
              pvIntArray->setLength(100);
              pvIntArray->putFrom(data);
              cout << " put time index \n";
          if (ind == 4) {
          PVByteArrayPtr pvByteArray = static_pointer_cast<PVByteArray>(pvField);
              cout << " pvByteArray len : " << pvByteArray->getLength() << "\n";
              pvByteArray->setLength(100);
              pvByteArray->putFrom(dbyte);
              cout << " put byte dummy \n";
              break;
I have now inserted a byte array. This looks good on both sides. I still suspect some problem with "pointer arithmetic" or something similar.
[junkes@dune epics]$  pvmonitor -r "" CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK structure
    string[] labels ["x", "y", "z", "time_index", "b"]
    structure value
        double[] column0 [9,17,25,33,41,49,57,65,73,81,89,97,105,13,21,29,37,45,53,61,69,77,85,93,101,109,17,25,33,41,49,57,65,73,81,89,97,105,2.97079e-313,6.36599e-313,9.76118e-313,1.31564e-312,1.65516e-312,1.99468e-312,2.3342e-312,1.07459e-13,3.53996e-307,2.42092e-322,7.58846e-301,0,6.36599e-314,3.06163e-296,1.50212e-231,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column1 [10,18,26,34,42,50,58,66,74,82,90,98,106,14,22,30,38,46,54,62,70,78,86,94,102,110,5.09279e-313,8.48798e-313,1.18832e-312,1.52784e-312,1.86736e-312,2.20688e-312,9.9872e-130,2.90517e+180,3.03934e-296,1.91562e+53,6.7687e-322,0,0,2.42092e-322,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column2 [11,19,27,35,43,51,59,67,75,83,91,99,107,3.81959e-313,7.21479e-313,1.061e-312,1.40052e-312,1.74004e-312,2.07956e-312,8.59816e-246,2.49375e+64,6.29808e-311,9.7588e-28,2.1371e-316,0,0,1.23516e-322,3.0615e-296,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        int[] column3 [12,16,20,24,28,32,36,40,44,48,52,56,60,64,68,72,76,80,84,88,92,96,100,104,108,2832,353769240,623257384,892745528,1162233672,1431721816,1701209960,2944,1,43255496,43245712,43245968,43255496,1414742849,1258291200,5352728,169090561,-186801060,0,0,0,0,0,2147483647,441169862,0,0,0,251,5328084,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        byte[] column4 [13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112]
    long counter 9
    string descriptor
    structure timeStamp
        long secondsPastEpoch 0
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK <Disconnect>
    structure value
        double[] column0 []
        double[] column1 []
        double[] column2 []
        int[] column3 []
        byte[] column4 []
    long counter 0
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
    structure value
        double[] column0 [0,8,16,24,32,40,48,56,64,72,80,88,96,4,12,20,28,36,44,52,60,68,76,84,92,100,8,16,24,32,40,48,56,64,72,80,88,96,1.061e-313,4.45619e-313,7.85138e-313,1.12466e-312,1.46418e-312,1.8037e-312,2.14322e-312,2.94319e-173,8.53851e+136,3.03934e-296,1.91562e+53,0,0,1.63042e-322,0,0,2.13693e-316,0,0,0,0,0,1.71457e-311,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column1 [1,9,17,25,33,41,49,57,65,73,81,89,97,5,13,21,29,37,45,53,61,69,77,85,93,101,3.18299e-313,6.57819e-313,9.97338e-313,1.33686e-312,1.67638e-312,2.0159e-312,2.69662e-289,7.84891e+20,4.79244e-322,9.7588e-28,0,0,4.24399e-314,5.37227e-304,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column2 [2,10,18,26,34,42,50,58,66,74,82,90,98,1.9098e-313,5.30499e-313,8.70018e-313,1.20954e-312,1.54906e-312,1.88858e-312,3.53992e-307,6.83066e-96,1.23516e-322,3.03994e-296,2.13694e-316,0,0,2.122e-314,0,0,5.37227e-304,0,0,0,0,0,2.13693e-316,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        int[] column3 [3,7,11,15,19,23,27,31,35,39,43,47,51,55,59,63,67,71,75,79,83,87,91,95,99,0,1,67438087,336926231,606414375,875902519,1145390663,1414878807,1684366951,5231008,0,43245584,43245840,0,978539597,1095189855,96,0,0,0,0,0,0,0,0,0,2,0,825241856,0,16225296,0,0,0,0,0,0,0,0,5389196,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,5389000,0,0,0,0,0,0,0,0,0,0]
        byte[] column4 [4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103]
    long counter 0
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
    structure value
        double[] column0 [1,9,17,25,33,41,49,57,65,73,81,89,97,5,13,21,29,37,45,53,61,69,77,85,93,101,9,17,25,33,41,49,57,65,73,81,89,97,1.2732e-313,4.66839e-313,8.06358e-313,1.14588e-312,1.4854e-312,1.82492e-312,2.16444e-312,2.31943e-52,3.53996e-307,2.42842e-315,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column1 [2,10,18,26,34,42,50,58,66,74,82,90,98,6,14,22,30,38,46,54,62,70,78,86,94,102,3.39519e-313,6.79039e-313,1.01856e-312,1.35808e-312,1.6976e-312,2.03712e-312,1.99536e-168,5.78708e+141,3.03934e-296,1.91562e+53,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column2 [3,11,19,27,35,43,51,59,67,75,83,91,99,2.122e-313,5.51719e-313,8.91238e-313,1.23076e-312,1.57028e-312,1.9098e-312,1.85165e-284,5.3866e+25,2.42842e-315,9.7588e-28,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        int[] column3 [4,8,12,16,20,24,28,32,36,40,44,48,52,56,60,64,68,72,76,80,84,88,92,96,100,0,219025168,488513312,758001456,1027489600,1296977744,1566465888,0,1,16225296,43245712,43245968,16225296,1414742849,1258291200,16225296,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        byte[] column4 [5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103,104]
    long counter 1
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
On the RTEMS-side all seems to be ok:
PvaClientPut::getData channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
PvaClientPut::checkConnectState channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
structure
    structure value
        double[] column0 []
        double[] column1 []
        double[] column2 []
        int[] column3 []
        byte[] column4 []
    long counter 0
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
bis hierhin ging es gut
counterField : 0
labels : {5}[x, y, z, time_index, b]
starting field column0 ... x
type scalarArray
 pvDoubleArray len : 0
 put x
starting field column1 ... y
type scalarArray
 put y
starting field column2 ... z
type scalarArray
 put z
starting field column3 ... time_index
type scalarArray
 pvIntArray len : 0
 put time index
starting field column4 ... b
type scalarArray
 pvByteArray len : 0
 put byte dummy
PvaClientPut::issuePut channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK pvStructure
structure
    structure value
        double[] column0 [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99]
        double[] column1 [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100]
        double[] column2 [2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101]
        int[] column3 [3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102]
    long counter 0
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
 bitSet {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17}
PvaClientPut::putDone channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK status.isOK true
putDone CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK status Status [type=OK]
 counter : 1
counterField : 0
type scalarArray
 pvDoubleArray len : 100
 put x
type scalarArray
 put y
type scalarArray
 put z
type scalarArray
 pvIntArray len : 100
 put time index
type scalarArray
 pvByteArray len : 100
 put byte dummy
structure
    structure value
        double[] column0 [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100]
        double[] column1 [2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101]
        double[] column2 [3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102]
        int[] column3 [4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103]
    long counter 1
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
 counter : 2
But my client works only once after starting the server :-(
I have already set the stack to epicsThreadStackSizeBig ;-)
Danke,
Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: PvData , PvAccess, Confusion with different hardware architectures Michael Davidsaver via Tech-talk
PvData , PvAccess, Confusion with different hardware architectures Heinz Junkes via Tech-talk
Prev: Re: ADpython issues with openCV J. Lewis Muir via Tech-talk
Next: Re: PvData , PvAccess, Confusion with different hardware architectures Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: PvData , PvAccess, Confusion with different hardware architectures Michael Davidsaver via Tech-talk
ANJ, 03 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
