1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PvData , PvAccess, Confusion with different hardware architectures
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Heinz Junkes <[email protected]>
Date: Tue, 2 Apr 2019 09:06:37 -0700
On 4/2/19 8:12 AM, Heinz Junkes via Tech-talk wrote:
> Hi folks,
> I am running a PvData client on RTEMS on a MVME6100 (PPC) and I see a behaviour that I can't even classify:
Then I think we should try to isolate where in the stack the problem(s) are.
There are a lot of different modules involved.
Could you try replacing your client code with something based on the following?
> #include <pv/pvData.h>
> #include <pva/client.h>
> namespace pvd = epics::pvData;
> struct Example {
>     pvac::ClientProvider ctxt;
>     pvac::ClientChannel chan;
>     Example()
>         :ctxt("pva")
>         ,chan(ctxt.connect("CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK"))
>     void put(long val) {
>         pvd::shared_vector<double> X, Y, Z, T;
>         for(long i=0; i<100; i++)
>             X.push_back(i);
>             Y.push_back(i+1);
>             Z.push_back(i+2);
>             T.push_back(i+3);
>         chan.put()
>                 .set("value.column0", pvd::freeze(X))
>                 .set("value.column1", pvd::freeze(Y))
>                 .set("value.column2", pvd::freeze(Z))
>                 .set("value.column3", pvd::freeze(T))
>                 .set("counter", val)
>                 .exec();
>         std::cout<<chan.get();
> PV-Server is a pythonIOC running on a linux - system. The PvStructure is this:
Do you see the same behavior with a P4P server. eg.
> from p4p.nt import NTTable
> from p4p.server import Server, StaticProvider
> from p4p.server.thread import SharedPV
> mystruct = NTTable.buildType(columns=[
>     ('column0', 'ad'),
>     ('column1', 'ad'),
>     ('column2', 'ad'),
>     ('column3', 'ai'),
> ], extra=[
>     ('counter', 'l'),
> pv = SharedPV(initial=mystruct({}))
> @pv.put
> def handler(pv, op):
>     print("Update with", op.value())
>     pv.post(op.value())
> provider = StaticProvider('myexample')
> provider.add('CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK', pv)
> Server.forever([provider])
Test with
> pvput CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK \
>   value.column0=[1,2,3] \
>   value.column1=[2,3,4] \
>   value.column2=[3,4,5] \
>   value.column3=[4,5,6] \
>   counter=1
> CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK structure
>     string[] labels
>     structure value
>         double[] column0
>         double[] column1
>         double[] column2
>         int[] column3
>     long counter
>     string descriptor
>     structure timeStamp
>         long secondsPastEpoch
>         int nanoseconds
>         int userTag
>     structure alarm
>         int severity
>         int status
>         string message
I don't see anything obviously wrong with the following, but make a few minor comments
below.
> On the RTEMS-CPU the following code is used:
> funktion put( long val ) // gets called put ([0…9])
> PvaClientPutDataPtr putData = pvaClientPut->getData();
>         PVLongPtr counterField = putData->getPVStructure()->getSubField<PVLong>("counter");
>         cout << "counterField : " << counterField << "\n";
I've trained myself to use getSubFieldT() by default, unless I explicitly
plan to test for NULL.  Avoids some surprises.
>         //shared_vector<std::string> labels;
>         PVStringArrayPtr labels = putData->getPVStructure()->getSubField<PVStringArray>("labels");
>         PVStringArray::const_svector l(labels->view());
>         //cout << "labels : "<< labels->view() << "\n";
>         //for(unsigned int i = 0; i < labels->getCapacity(); i++ ) {
>         //  cout << "label index " << i << " : " << l[i] << "\n";
>         shared_vector<double> newX(100);
>           //PVIntArray::svector newTimeIndex;
>         for(int i=0; i < 100; i++) newX[i] = 0 + i;
>         shared_vector<const double> x(freeze(newX));
>         shared_vector<double> newY(100);
>         for(int i=0; i < 100; i++) newY[i] = 1 + i;
>         shared_vector<const double> y(freeze(newY));
>         shared_vector<double> newZ(100);
>         for(int i=0; i < 100; i++) newZ[i] = 2 + i;
>         shared_vector<const double> z(freeze(newZ));
>         shared_vector<int32> newTimeIndex(100);
>         for(int i=0; i < 100; i++) newTimeIndex[i] = 3 + i;
>         shared_vector<const int32> data(freeze(newTimeIndex));
>        //PVStructurePtr pvValue = putData->getPVStructure();
>        // pvValue->dumpValue(cout);
>         PVStructurePtr pvStructure = putData->getPVStructure()->getSubField<PVStructure>("value");
>         if(!pvStructure) {
>             cout << "value is not a structure\n";
>             return;
>         PVFieldPtrArray pvFields = pvStructure->getPVFields();
>         for(size_t ind = 0; ind < pvFields.size() ; ++ind)
>           PVFieldPtr pvField = pvFields[ind];
>           cout << "starting field " << pvField->getFieldName() << " ... " << l[ind] << "\n";
>           cout << "type " << pvField->getField()->getType() << "\n";
>           if(pvField->getField()->getType()!=scalarArray) {
>             cout << "fields is not a scalar array\n";
>             continue;
>           PVScalarArrayPtr pvScalarArray = static_pointer_cast<PVScalarArray>(pvField);
>           pvScalarArray->setLength(100);
This setLength() call isn't necessary.  It does an allocation which is then
replaced by the putFrom() below.
>           switch (ind) {
>             case 0: pvScalarArray->putFrom(x); cout << " put x \n"; break;
>             case 1: pvScalarArray->putFrom(y); cout << " put y \n"; break;
>             case 2: pvScalarArray->putFrom(z); cout << " put z \n"; break;
>             case 3: pvScalarArray->putFrom(data); cout << " put data \n"; break;
>         counterField->put(val);
>         pvaClientPut->issuePut();
> On the RTEMS CPU it self I read:
> PvaClientPut::checkConnectState channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
> counterField : 0
> starting field column0 ... x
> type scalarArray
>  put x
> starting field column1 ... y
> type scalarArray
>  put y
> starting field column2 ... z
> type scalarArray
>  put z
> starting field column3 ... time_index
> type scalarArray
>  put data
> PvaClientPut::issuePut channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK pvStructure
> structure
>     string[] labels ["x", "y", "z", "time_index"]
>     structure value
>         double[] column0 [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99]
>         double[] column1 [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100]
>         double[] column2 [2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101]
>         int[] column3 [3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102]
>     long counter 1
>     string descriptor
>     structure timeStamp
>         long secondsPastEpoch 0
>         int nanoseconds 0
>         int userTag 0
>     structure alarm
>         int severity 0
>         int status 0
>         string message
>  bitSet {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16}
> PvaClientPut::putDone channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK status.isOK true
> putDone CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK status Status [type=OK]
>  counter : 2
> PvaClientPut::getData channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
> counterField : 1
> type scalarArray
>  put x
> type scalarArray
>  put y
> type scalarArray
>  put z
> type scalarArray
>  put data
> structure
>     structure value
>     long counter 2
>     string descriptor
>     structure timeStamp
>         int nanoseconds 0
>         int userTag 0
>     structure alarm
>         int severity 0
>         int status 0
>         string message
> On a Darwin - host with
> pvmonitor -r "" CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
> I read:
>     structure value
>         double[] column0 [0,8,16,24,32,40,48,56,64,72,80,88,96,0,0,2.122e-314,5,13,21,29,37,45,53,61,69,77,85,93,3.49671e-307,6,14,22,30,38,46,54,62,70,78,86,94,3.49671e-307,7,15,23,31,39,47,55,63,71,79,87,95,3.49671e-307,2.75859e-313,6.15379e-313,9.54898e-313,1.29442e-312,1.63394e-312,1.97346e-312,6.2132e-311,2.14309e-314,0,0,2.122e-314,2,10,18,26,34,42,50,58,66,74,82,90,98,6,14,22,30,38,46,54,62,70,78,86,94,2.02073e-321,3.60739e-313,7.00259e-313,1.03978e-312,1.3793e-312,1.71882e-312,2.05834e-312,2.43117e-315,0]
>         double[] column1 [1,9,17,25,33,41,49,57,65,73,81,89,97,5,13,21,29,37,45,53,61,69,77,85,93,101,3.18299e-313,6.57819e-313,9.97338e-313,1.33686e-312,1.67638e-312,2.0159e-312,2.09612e-296,5.26795e-304,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
>         double[] column2 [2,10,18,26,34,42,50,58,66,74,82,90,98,1.9098e-313,5.30499e-313,8.70018e-313,1.20954e-312,1.54906e-312,1.88858e-312,5.26795e-304,3.05017e+06,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
>         int[] column3 [3,7,11,15,19,23,27,31,35,39,43,47,51,55,59,63,67,71,75,79,83,87,91,95,99,0,42691016,42691272,16195288,1414742849,1258291200,16195288,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
>     long counter 1
>     string descriptor
>     structure timeStamp
>         int nanoseconds 0
>         int userTag 0
>     structure alarm
>         int severity 0
>         int status 0
>         string message
>     structure value
>         double[] column0 [0,8,16,24,32,40,48,56,64,72,80,88,96,1,9,17,25,33,41,49,57,65,73,81,89,97,2,10,18,26,34,42,50,58,66,74,82,90,98,6.36599e-314,4.03179e-313,7.42699e-313,1.08222e-312,1.42174e-312,1.76126e-312,2.10078e-312,5.09279e-313,1.86736e-312,0,0,9.16401e-72,5,13,21,29,37,45,53,61,69,77,85,93,1.71457e-311,9,17,25,33,41,49,57,65,73,81,89,97,1.4854e-313,4.88059e-313,8.27578e-313,1.1671e-312,1.50662e-312,1.84614e-312,4.29492e-311,1.6458e+98,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
>         double[] column1 [1,9,17,25,33,41,49,57,65,73,81,89,97,2,10,18,26,34,42,50,58,66,74,82,90,98,6.36599e-314,4.03179e-313,7.42699e-313,1.08222e-312,1.42174e-312,1.76126e-312,2.10078e-312,5.09279e-313,1.86736e-312,0,0,9.16401e-72,5,13,21,29,37,45,53,61,69,77,85,93,1.71457e-311,9,17,25,33,41,49,57,65,73,81,89,97,1.4854e-313,4.88059e-313,8.27578e-313,1.1671e-312,1.50662e-312,1.84614e-312,4.29492e-311,1.6458e+98,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
>         double[] column2 [2,10,18,26,34,42,50,58,66,74,82,90,98,6.36599e-314,4.03179e-313,7.42699e-313,1.08222e-312,1.42174e-312,1.76126e-312,2.10078e-312,5.09279e-313,1.86736e-312,0,0,9.16401e-72,5,13,21,29,37,45,53,61,69,77,85,93,1.71457e-311,9,17,25,33,41,49,57,65,73,81,89,97,1.4854e-313,4.88059e-313,8.27578e-313,1.1671e-312,1.50662e-312,1.84614e-312,4.29492e-311,1.6458e+98,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
>         int[] column3 [3,7,11,15,19,23,27,31,35,39,43,47,51,55,59,63,67,71,75,79,83,87,91,95,99,2904,1,42698272,24,0,5205556,1095189855,88,0,0,0,0,0,0,0,0,0,2,0,825241856,0,42693840,1074266112,1075052544,1075576832,1075970048,1076232192,1076494336,1076756480,1076953088,1077084160,1077215232,1077346304,1077477376,1077608448,1077739520,1077870592,1077968896,1078034432,1078099968,1078165504,1078231040,1078296576,1078362112,1078427648,1078493184,1078558720,1078624256,1078689792,1078755328,1078820864,1078886400,1078951936,1079001088,1079033856,1079066624,1079099392,1079132160,1079164928,1079197696,1079230464,1079263232,1079296000,1079328768,1079361536,1079394304,1079427072,1079459840,1079492608,1079525376,1079558144,808,1074266112,1075052544,1075576832]
>     long counter 2
>     string descriptor
>     structure timeStamp
>         int nanoseconds 0
>         int userTag 0
>     structure alarm
>         int severity 0
>         int status 0
>         string message
> Only every 4th element is included in the  int array (ind == 3) and every 8th element in the double arrays (ind == 0-2)?
> If I run the client code on the Darwin host, everything looks fine. All 100 elements are taken over in the arrays on the server.
>     structure value
>     long counter 9
>     string descriptor
>     structure timeStamp
>         int nanoseconds 0
>         int userTag 0
>     structure alarm
>         int severity 0
>         int status 0
>         string message
> Does anyone have any idea what's happening?
> I guess of course something with type-len (int ==4, double ==8).
> Danke, Heinz
Re: PvData , PvAccess, Confusion with different hardware architectures Heinz Junkes via Tech-talk
Re: PvData , PvAccess, Confusion with different hardware architectures Michael Davidsaver via Tech-talk
Prev: Re: EPICS Base 3.15 release notes epicsVersion.h macro snippet issues J. Lewis Muir via Tech-talk
Next: Splitting the motor module Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: PvData , PvAccess, Confusion with different hardware architectures Heinz Junkes via Tech-talk
Next: Re: PvData , PvAccess, Confusion with different hardware architectures Heinz Junkes via Tech-talk
ANJ, 08 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
