1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Coordinated motion of slits
From: "giles.knap--- via Tech-talk" <[email protected]>
To: "Davis, Mark" <[email protected]>, Tech Talk <[email protected]>
Date: Tue, 30 Apr 2019 07:26:39 +0000
I'm seeing this exact issue on my power clipper. It has started happening since I factory reset the configuration.
I have yet to work out which setting(s) are responsible but intend to spend time on this next week.
From: [email protected] <[email protected]> on behalf of Davis, Mark via Tech-talk <[email protected]>
Sent: 29 April 2019 21:02:57
To: [email protected]
Hi George,
Does it work properly with motor records mapped to the actual motors?
I had this problem early on when first working with the Power Brick controller where I had one motor record per motor (no coordinate systems involved), and eventually someone figured out that I needed to set the InPosBand value for each motor to a small (non-0) value to get the controller status to indicate when the last motion completed.
If, in addition to the motor records mapped to the coordinate axes, you have a motor record mapped to each motor, and THEY show that the motion of each motor has completed, then that is probably NOT the problem.
NOTE:  I don't remember exactly where it was, but I just last week I read something (I THINK it was in one of the Power PMAC manuals, but it MIGHT have been about the driver, or even the EPICS Model 3 motor interface) that specified which (few) values that are available for actual motors that were also supported for coordinate system axes.  I don't remember if it included the movement-completed status or not, but that is something else to look at.
Hopefully I will have time this week to catch up with where you are at and then there will be one more person looking at the problem.
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]<mailto:[email protected]>
On 4/29/2019 3:13 PM, George Nicolas Kontogiorgos via Tech-talk wrote:
Hi all,
I am working on a slit setup controlled by Power PMAC using EPICS too. By now I could create a virtual axis as Wayne mentioned on cmd and substitutions files and I can drive the motors using the kinematics transformation on delta tau. The setpoints and readbacks are working fine.
My problem is after the first movement, I can’t perform another movement without resetting my IOC or manually stopping movement with SPMG value. I think that the problem is with DMOV, which never return to one (stopped condition) and do not allow another movement. Should I map this variable on my PLC or motion programs? If so, how could I do that?
Thanks a lot
Best regards
Electrical Engineer
Beamline Software Group (SOL)
Brazilian Synchrotron Light Laboratory (LNLS)
www.lnls.cnpem.br<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.lnls.cnpem.br_&d=DwMFAg&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=Z-VqleBC-AcDJnuOcYeO6eibRfwMG8LbGa444-jfBKI&s=3HhxdzhV6IA67Hqyud6gTnV2Txr2BG89QJ4fUWltCnQ&e=>
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Coordinated motion of slits George Nicolas Kontogiorgos via Tech-talk
Re: Coordinated motion of slits Davis, Mark via Tech-talk
Prev: Re: Coordinated motion of slits Davis, Mark via Tech-talk
Next: Fwd: Re: EDM on stretch Christoph Schroeder via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: motor R7-0 released Peterson, Kevin M. via Tech-talk
ANJ, 30 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
