1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Record not processing in simulation mode
From: "Konrad, Martin via Tech-talk" <[email protected]>
To: Eric Norum <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 13 May 2019 19:00:11 +0000
Hi Eric,
> Yes, that is the expected behaviour.    Here’s the salient section
> from the application developer’s guide — note the last clause:
>> The record will be processed only if link’s Process Passive
>> attribute is PP and the target record’s SCAN field is Passive.
Sorry, I forgot to mention that it doesn't work with SCAN=Passive
either. Does the sentence above suggest that I'm responsible for
triggering record processing manually if I'm not getting my simulation
value through a link? If so this would make it more tedious to switch a
record into simulation mode from some external code that interacts with
the IOC through Channel Access (e.g. a Python script).
Thanks!
Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Record not processing in simulation mode Konrad, Martin via Tech-talk
Prev: Record not processing in simulation mode Konrad, Martin via Tech-talk
Next: Re: Record not processing in simulation mode Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 13 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
