Using simulation mode for the first time I noticed some behavior I
didn't expect.
When I use the attached simple database and perform the following puts
caput foo.SIMM YES
caput foo.SVAL 42
foo.VAL changes to 42. This is what I expect.
However, when I try the same thing with a record that is tied to
hardware (also RTYP=ai but DTYP=asynFloat64, SCAN=I/O Intr) the record
doesn't process on writes to the SVAL field. Poking it manually ("caput
foo.PROC 1") triggers processing, though.
Is this how it should be? If so can someone shine some light on why it
is behaving like this?
Thanks a lot,
Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
record(calc, "random") {
field(CALC, "RNDM")
field(SCAN, "1 second")
record(ai, "foo") {
field(INP, "random CPP MS")
- Re: Record not processing in simulation mode Ralph Lange via Tech-talk
Using PVUtil to get PV's value when PV name is input as string in CSS Tyler Lemon via Tech-talk
Re: Record not processing in simulation mode Konrad, Martin via Tech-talk
<2019>
2025
2026
Re: Using PVUtil to get PV's value when PV name is input as string in CSS Tyler Lemon via Tech-talk
<2019>
2025
2026
