1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Should drvAsynIPPortConfigure print an error when device is not connected?
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Wed, 15 May 2019 10:28:23 +0000
Totally forgot about this issue. Same issue here with Asyn 4.34 and stream 2.8.8, we started facing this issue with stream 2.8.8. I think when we used 2.7.7c it was reporting disconnected devices.
Best Regards,
Abdalla.
From: [email protected] [mailto:[email protected]] On Behalf Of Paduan Donadio, Marcio via Tech-talk
Sent: Wednesday, May 15, 2019 3:56 AM
To: [email protected]
Subject: Should drvAsynIPPortConfigure print an error when device is not connected?
Hello, all.
When calling drvAsynIPPortConfigure on the IOC, shell passing an IP of a disconnected device, no message is print on the IOC shell. Is there a way to configure it?
Thank you,
Márcio
Márcio Paduan Donadio | Control Systems Engineer
Advanced Control Systems Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.5007 | w: slac.stanford.edu
RE: Should drvAsynIPPortConfigure print an error when device is not connected? Mark Rivers via Tech-talk
Should drvAsynIPPortConfigure print an error when device is not connected? Paduan Donadio, Marcio via Tech-talk
Prev: Re: RES: Pmac Slits giles.knap--- via Tech-talk
Next: Request for Response of Projects that Use EPICS bob dalesio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Should drvAsynIPPortConfigure print an error when device is not connected? Paduan Donadio, Marcio via Tech-talk
Next: RE: Should drvAsynIPPortConfigure print an error when device is not connected? Mark Rivers via Tech-talk
ANJ, 15 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
