1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning 101
From: Hinko Kocevar via Tech-talk <[email protected]>
To: "Jemian, Pete R." <[email protected]>
Date: Wed, 29 May 2019 17:02:42 +0000
Pete, I will surely check out this tool, even if it goes beyond EPICS Db only approach that I mentioned before. In fact, some of the resourceful people at my facility have already started using python based tools to tackle the task of scanning on top of sscan based EPICS solution.
Hinko
> On 28 May 2019, at 19:50, Jemian, Pete R. via Tech-talk <[email protected]> wrote:
>> On 2019-05-23 3:12 AM, Hinko Kocevar via Tech-talk wrote:
>> Imagine an EPICS developer with no experience in working with (coordinated) scanning application.
>> The sub-units, of the system in need of scanning feature, include timing system with precision triggering and timestamping, 1 to several axes of motion, control of HV bias and 1 to several channels of data acquisition. You can assume that the (low-level) EPICS modules supporting the hardware are under my control already, I'm interested in orchestrating the scan using above constituents.
>> What would be preferred approach to tackle this subject with EPICS in 2019?
>> TIA,
>> Hinko
> The Bluesky data collection framework from NSLS-II/BNL can satisfy your
> requirements except, possibly, for the precision triggering depending on
> the order of magnitude of that precision.  Bluesky is python 3.6+
> software running as an EPICS client with support of:
> * orchestration of scans of 1-D and higher dimensionality
> * timestamps for all acquired data
> * one or more streams of event data
> * support for the EPICS motor record and area detector
> * database for scan data
> documentation: https://blueskyproject.io/bluesky/
> source: https://github.com/bluesky
> Regards,
>    Pete
> Pete R. Jemian, Ph.D.                 <[email protected]>
> Beam line Controls and Data Acquisition (BC, aka BCDA)
> Advanced Photon Source,    Argonne National Laboratory
> Argonne, IL  60439                    630 - 252 - 3189
>       Education is the one thing for which people
>          are willing to pay yet not receive.
Scanning 101 Hinko Kocevar via Tech-talk
Re: Scanning 101 Jemian, Pete R. via Tech-talk
Prev: devSup driver development differences between base 3.14 and 3.15 Abdalla Ahmad via Tech-talk
Next: RE: devSup driver development differences between base 3.14 and 3.15 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Scanning 101 Jemian, Pete R. via Tech-talk
Next: Ip kernel mbuf starvation on RTEMS 4.11 Antonio Lucio via Tech-talk
ANJ, 29 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
