1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Scanning 101
From: "tom.cobb--- via Tech-talk" <[email protected]>
To: Hinko Kocevar <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 3 Jun 2019 09:31:50 +0000
Hi Hinko,
You may already have this covered with ethercat, but if you need some hardware that will average encoders and/or ADC value over possibly uneven hardware gates you can do this with PandABox:
https://www.ohwr.org/project/pandabox/wikis/home
For orchestrating hardware together to perform a hardware synchronized scan, Diamond has taken a different approach to Bluesky. We provide a Python middlelayer scanning service (Malcolm) that configures and supervises the underlying devices via CA, then exposes a higher level PVA interface up that the UI can use. This is because we already have a user facing application http://www.opengda.org/ so we needed a service that could provide hardware triggered scanning, rather than a top level application that could be given to end users.
Paper: http://accelconf.web.cern.ch/AccelConf/icalepcs2017/papers/tupha159.pdf
Docs: https://pymalcolm.readthedocs.io/en/latest/
Repo: https://github.com/dls-controls/pymalcolm
Tom
> -----Original Message-----
> From: [email protected] <[email protected]> On
> Behalf Of Hinko Kocevar via Tech-talk
> Sent: 25 May 2019 16:36
> To: Mark Rivers <[email protected]>
> Cc: [email protected]
> Subject: Re: Scanning 101
> Mark, regarding the timing, I'm working with MRF EVG/EVR timing system.
> I'm mostly looking at uTCA AMC or IPC PCI based cards.
> As you probably know, one would use mrfioc2 to configure EVR to produce
> triggers on a backplane or frontpanel upon receiving an event from EVG.
> In addition, EVR can keep track of (absolute) time to be used to timestamp
> records of choice (through TSEL field).
> The machine repetition rate is 14Hz, and I would like to have relevant PVs all
> be timestamped at that precision.
> The (soft) IOC runs on Linux based OS, and it could potentially incorporate all
> the support modules needed for scanning (DAQ, motion, timing,..).
> Torsten, motion controller in my case is from ESS MCAG, ecmc based,
> AFAICT. I would need to more insight into the motor control and how it could
> be coupled with scanning application, though. Will contact you offline for
> some guidance, if I may, especially in regard to EVR timestamping.
> I would like to stick to the EPICS records to perform scanning, and not rely on
> other codes and/or programing languages. I can not tell if this (self-imposed)
> restrictions are getting me the furthest, though.
> To elaborate, my /simplest/ use case is:
>  * single axis motor control, w/ encoder readout and limit switch handling
> based on Ethercat (ESS ecmc)
>  * single DAQ channel
>  * EVR triggered DAQ
>  * EVR timestamped (cherry picked) PV
>  * optionally control other units (HV bias,..)
> I want to:
> * move the motor in position (let is settle?),
> * check limit switches,
> * read encoder values,
> * acquire several waveforms (optionally perform waveform averaging / ROI /
> other processing to produce a single value),
> * timestamp my favorite PVs,
> * archive (using Archiver Aappliance or HDF5 file or ??) all my favorite PVs,
> * .. repeat the above steps n-times
> The ultimate goal is to be able to retrieve the archived PVs and correlate
> them using the timestamp in order to reconstruct the measurement/scan.
> Will look into sscan module docs.
> Would one use EPICS sequencer for any reason with scanning?
> Is there a minimalistic (dummy) IOC to be studied that does scanning?
> Thanks!
> //hinko
> From: Mark Rivers <[email protected]>
> Sent: Thursday, May 23, 2019 12:37:32 PM
> To: Hinko Kocevar
> Hi Hinko,
> My first response would be to use the sscan record. But I need more
> explanation of what you mean by "timing system with precision triggering
> and timestamping".
> Mark
> Sent from my iPhone
> > On May 23, 2019, at 4:12 AM, Hinko Kocevar via Tech-talk <tech-
> [email protected]> wrote:
> > Imagine an EPICS developer with no experience in working with
> (coordinated) scanning application.
> > The sub-units, of the system in need of scanning feature, include timing
> system with precision triggering and timestamping, 1 to several axes of
> motion, control of HV bias and 1 to several channels of data acquisition. You
> can assume that the (low-level) EPICS modules supporting the hardware are
> under my control already, I'm interested in orchestrating the scan using
> above constituents.
> > What would be preferred approach to tackle this subject with EPICS in
> 2019?
> > TIA,
> > Hinko
Re: Scanning 101 Hinko Kocevar via Tech-talk
Re: Scanning 101 Mark Rivers via Tech-talk
Prev: Re: more setpoint oddities with pmac driver and CS axes giles.knap--- via Tech-talk
Next: Re: [EXTERNAL] Re: How to share asyn's queue thread among ports? Klemen Vodopivec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Scanning 101 Hinko Kocevar via Tech-talk
Next: Re: Scanning 101 Hinko Kocevar via Tech-talk
ANJ, 03 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
