1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Running EPICS R3.14.12.7 in RTEMS 4.11
From: Michael Davidsaver via Tech-talk <[email protected]>
Date: Wed, 26 Jun 2019 18:25:27 -0700
Hello Emilio,
Have you seen?  https://github.com/epics-base/epics-base/
We do now accept pull requests there.
The current focus of development is the 7.0 branch.
FYI there is ongoing work by Heinz Junkes to support the (in progress) RTEMS 5 release.
On 6/26/19 11:13 AM, emilio.perez-juarez--- via Tech-talk wrote:
> Hi all, I hope you are well,
> I would like to share some progress in updating EPICS R3.14.12.7 to support RTEMS 4.11, in this case running on a MVME5500.
> It's a work in progress but we managed to run rtemsTestsHarness, getting the following message:
>     EPICS Test Harness Results
> All tests successful.
> Programs=27, Tests=2297, 343 wallclock secs
> You can find the changes in the last commits of my local fork: https://github.com/hir12111/epics-base
> <https://github.com/hir12111/epics-base>
> A couple of changes in non-epics repos are also required:
>  - In RTEMS file 'src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c':  you need to define the macro MAX (this may not be an issue for you if you are not using MVME5500),
>  - In libbspExt file 'libbspExt/dabrBpnt.c': you need to avoid the use of fp->EXC_DAR, as that field was deleted from the exception frame some time ago, and it wasn't used anyways.
> I wonder why that repo is not included in epics-base.
> Please let me know if you have any comments.
> Best regards and thank you,
> Emilio
Re: Running EPICS R3.14.12.7 in RTEMS 4.11 emilio.perez-juarez--- via Tech-talk
Prev: Beckhoff BK9000 support survey Dunning, Michael via Tech-talk
Next: Fwd: Beckhoff BK9000 support survey Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Running EPICS R3.14.12.7 in RTEMS 4.11 emilio.perez-juarez--- via Tech-talk
Next: Re: Running EPICS R3.14.12.7 in RTEMS 4.11 emilio.perez-juarez--- via Tech-talk
ANJ, 26 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
