Hello,
at LNL-INFN (Italy) we are using the same beckhoff modules using the epics
modbus module.
This works well enough for us, but some modules have internal register that
cannot be accessed directly (register communication).
For this reason we developed a asynPortDriver interface to be able to access the
internal registers of the KL2541 stepper motor module as part of the whole motor
record support for that module.
We would be interested in any improved interface to these modules.
Thank you,
Davide
On 27/06/19 2:17 AM, Dunning, Michael via Tech-talk wrote:
At SLAC we use Beckhoff bus terminals quite extensively because they
are inexpensive and reliable, but unfortunately don't yet have a
common epics support solution. We have at least three versions of
support which were developed independently.
One version uses only the epics modbus module. This has no driver so
requires less maintenance, but makes setting up IOCs more time
consuming and results in a lot of code duplication.
Another version uses asynPortDriver and some custom modbus code. This
is designed to make setting up IOCs easier, but requires maintenance
of the driver code.
Another uses custom epics device support. This requires writing
device support for each bus terminal, and has resulted in a pretty
ugly codebase. This is our least favored solution going forward.
A typical installation would be a BK9000 bus coupler plus several
analog and/or digital I/O modules (e.g. KL2114, KL1104, KL3172,
KL3314), communicating over ethernet using Modbus TCP.
Before we settle on a solution, we'd like to see what everyone else is
doing. Any responses would be helpful.
Thank you,
Mike
Michael Dunning
SLAC National Accelerator Laboratory
2575 Sand Hill Road
Menlo Park, CA 94025
(650) 926-5200
Davide Marcato
INFN - Laboratori Nazionali di Legnaro
Viale dell'Universita', 2
35020 Legnaro (PD) - ITALY
Phone: +39 0498068439
Mail: [email protected]
- Beckhoff BK9000 support survey Dunning, Michael via Tech-talk
Re: Running EPICS R3.14.12.7 in RTEMS 4.11 emilio.perez-juarez--- via Tech-talk
RE: [EXTERNAL] Beckhoff BK9000 support survey Pearson, Matthew R. via Tech-talk
<2019>
2025
2026
Fwd: Beckhoff BK9000 support survey Mark Rivers via Tech-talk
<2019>
2025
2026
