1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Problems with stream device 2.8.8
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Sun, 7 Jul 2019 10:46:32 +0000
Hi
We are facing the following problems with version 2.8.8 and .9:
1.       Offline devices are not reported on the IOC shell when calling drvAsynIPPortConfigure.
2.       Exit command renders the IOC shell frozen, i.e. the IOC does not exit.
We faced #2 before, but I want to ask is it asyn or stream device problem? Because I want to try different versions but I’m not sure whether asyn or stream to change.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: Problems with stream device 2.8.8 Johnson, Andrew N. via Tech-talk
Prev: First EPICS Debian packages available for Debian 10 Konrad, Martin via Tech-talk
Next: EPICS Docker Container Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Problems with stream device 2.8.8 Johnson, Andrew N. via Tech-talk
ANJ, 08 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
