Dear all,
at the collaboration meeting last month I presented, that we are looking
into Docker containers for deploying and managing our EPICS
installations for the PANDA experiment.
I have now tested several things with containers for IOCs, ca-gateway,
phoebus and the archive-engine (from phoebus).
@Heinz: During the meeting you asked how the containers get access to
network devices: Actually, this is quiet easy. if you use the bridge
network driver from Docker for the virtual network your containers live in,
NATing is enabled by default. (Otherwise CMS which are usually run
inside of containers could not get their updates ;-) ). So even if you
run mutliple IOCs on the same host, accessing network devices is no problem.
For access those IOCs via CA from a remote host you need a CA gateway as
well. I also tested access to serial devices with asyn+stream.
One thing which is not working for me at the moment is PVaccess. For CA
i add the option `-p 5064-5065:5064-5065 -p 5064-5065:5064-5065/udp` to
publish the CA ports of my container (either IOC or ca-gateway) to the
outside world.
For PVaccess I tried with `-p 5075:5075 -p 5076:5076/udp` but this was
not working. Accessing the IOC from the host directly (via the virual
network) works. So the IOC has a PVaccess server.
Did I miss some important ports for PVaccess or is this protocol working
differently when establishing connections?
The IOC is connected to a virtual network with its own IP address. The
ports are mapped to the physical ports of my host system. The remote
client only "sees" the physical connection of my host.
If anyone is interested in this work let me know! We will establish our
own docker registry server soon, where the images will be made available.
Best regards,
Florian
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
- Re: EPICS Docker Container Lucas Russo via Tech-talk
Problems with stream device 2.8.8 Abdalla Ahmad via Tech-talk
re:EPICS Docker Container Jack Harper - UKRI STFC via Tech-talk
<2019>
2025
2026
Fwd: Problems with stream device 2.8.8 Mark Rivers via Tech-talk
<2019>
2025
2026
ANJ, 10 Jul 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
