1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Docker Container
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Jack Harper - UKRI STFC <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 8 Jul 2019 14:51:29 +0200
Hi Jack,
normally I also use compose files. But for testing I used the docker run command directly.
Using the host network also works for me to use pvget from a remote host. But if I want to have multiple IOCs running on the same host and want to use CA and PVaccess in parallel, I guess using the host network is not a good idea. IIRC you would need to define individual CAS ports for each IOC and tell all your clients to also use those ports. Therefore I wanted to have the IOCs in a virtual (bridge) network and use a PVaccess gateway in the end.
I was not able to have host network together with a bridge network inside one compose file...
Best regards,
Florian
On 7/8/19 2:38 PM, Jack Harper - UKRI STFC wrote:
Hi Florian,
I see what you mean. Yes, i have only tried running pvget from inside the container and on the host machine.
I have run it in host network mode and that seemed to work as well. I use a docker-compose file to do all the port matching so can't say what command line arguments would be best to use in your case, but using compose might be at least an option to set all the ports up instead of doing it every time when running the container? you can also use it to choose what type of network to run the container in.
Jack
Sent: 08 July 2019 13:27:01
To: Harper, Jack (STFC,RAL,ISIS)
Hey Jack,
yes, I have exposed the ports in the Dockerfile. But it is not working
for me.
Did you tried `pvget` on the same host, as the container is running on?
Than the network access happens via the virtual network of Docker.
Running a docker container with no arguments means, the container is
inside the default bridge network ( 172.17.0.0/16 ) and the host system
is connected to this network as 172.17.0.1.
This way pvget works for me. The problem is, accessing the IOC from a
different PC in the physical network. In this case you have to
explicitly publish the ports with the `-p` option of the docker run
command.
On 7/8/19 2:20 PM, Jack Harper - UKRI STFC via Tech-talk wrote:
Hi Florian,
Have you exposed your ports in the Dockerfile correctly?
I have just fixed this in one of the Dockerfiles i have been working on - here is the line that exposes the ports:
EXPOSE 5064 5065 5064/udp 5075 5076 5075/tcp 5076/udp
I had to be explicit that i was exposing 5075 as tcp and 5076 as udp - pv access would not work otherwise. I just run the container with no arguments and it seems to work.
Hope this helps,
Jack Harper
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
re:EPICS Docker Container Jack Harper - UKRI STFC via Tech-talk
Prev: re:EPICS Docker Container Jack Harper - UKRI STFC via Tech-talk
Next: Open Position at Los Alamos National Lab Nelsen, Ashley Nicole via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 08 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
