Hi Florian,
I'm using the script Ralph mentioned on [1] for Debian hosts and it works ok. I'm running a few dozen IOCs on some of my hosts.
Cheers!
Lucas
On Wed, Jul 10, 2019 at 11:35 AM Ralph Lange via Tech-talk < [email protected]> wrote: Hi Florian,
On Wed, 10 Jul 2019 at 14:17, Florian Feldbauer via Tech-talk <[email protected]> wrote:
My only concern is, if I want to run multiple IOCs on the same
host. (Never actually did that). Don't I have to set individual CA
Server ports for each IOC? PVaccess sets it's port dynamically if
the default port is already in use. This is a very common mode of operation, and: no, you don't have to apply specific settings to IOCs. The only caveat: If clients do not use broadcasts for name resolution, only one IOC will receive the name resolution request. (I.e. these clients only "see" the IOC that was started last.) The good news: there is a well-tested workaround for that issue; see [1]. I have seen setups between a few and hundreds of IOCs running on a single host.
Cheers, ~Ralph
- Re: EPICS Docker Container Florian Feldbauer via Tech-talk
- EPICS Docker Container Florian Feldbauer via Tech-talk
- Re: EPICS Docker Container Lucas Russo via Tech-talk
- Re: EPICS Docker Container Ralph Lange via Tech-talk
Re: Empty string as SNL macro Hovanes Egiyan via Tech-talk
Re: Empty string as SNL macro Benjamin Franksen via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 10 Jul 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
