Hi Florian,
On Wed, 10 Jul 2019 at 14:17, Florian Feldbauer via Tech-talk <[email protected]> wrote:
My only concern is, if I want to run multiple IOCs on the same
host. (Never actually did that). Don't I have to set individual CA
Server ports for each IOC? PVaccess sets it's port dynamically if
the default port is already in use. This is a very common mode of operation, and: no, you don't have to apply specific settings to IOCs. The only caveat: If clients do not use broadcasts for name resolution, only one IOC will receive the name resolution request. (I.e. these clients only "see" the IOC that was started last.) The good news: there is a well-tested workaround for that issue; see [1]. I have seen setups between a few and hundreds of IOCs running on a single host.
Cheers, ~Ralph
- Re: EPICS Docker Container Lucas Russo via Tech-talk
- EPICS Docker Container Florian Feldbauer via Tech-talk
- Re: EPICS Docker Container Florian Feldbauer via Tech-talk
RE: Problems with stream device 2.8.8 Abdalla Ahmad via Tech-talk
Re: Empty string as SNL macro Hovanes Egiyan via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 10 Jul 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
