1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems with stream device 2.8.8
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Wed, 10 Jul 2019 13:34:29 +0000
I faced the same issue with an IOC and I got this:
atExit save_restoreShutdown(nil)
atExit exitDatabase((nil))
atExit cacExitHandler((nil))
atExit errlogExitHandler((nil))
atExit cleanup(0x2412530)
atExit cleanup(0x2410870)
After that, the IOC shell is frozen, no output. This renders IOC stats PV “:SysReset” unusable at all.
Abdalla.
From: [email protected] <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: Monday, July 08, 2019 7:50 PM
To: [email protected]
Subject: Re: Problems with stream device 2.8.8
Hi Abdalla,
On 7/7/19 5:46 AM, Abdalla Ahmad via Tech-talk wrote:
Exit command renders the IOC shell frozen, i.e. the IOC does not exit.
We faced #2 before, but I want to ask is it asyn or stream device problem? Because I want to try different versions but I’m not sure whether asyn or stream to change.
We can't answer that, but you might get some more hints by running the command
    var atExitDebug 1
on the IOC shell before exiting. It causes a message to be printed before each of the registered epicsAtExit() routines gets run, so you should be able to see which routine is hanging.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Problems with stream device 2.8.8 Abdalla Ahmad via Tech-talk
Re: Problems with stream device 2.8.8 Johnson, Andrew N. via Tech-talk
Prev: Re: Empty string as SNL macro Benjamin Franksen via Tech-talk
Next: Re: EPICS Docker Container Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems with stream device 2.8.8 Zimoch Dirk (PSI) via Tech-talk
Next: Fwd: Problems with stream device 2.8.8 Mark Rivers via Tech-talk
ANJ, 10 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
