1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: spec epics_caget not working
From: "Jennings, Guy via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: "Miceli, Antonino" <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Mon, 5 Aug 2019 20:00:44 +0000
Agreed - unless there is a firewall rule explicit to caget
Sent from my iPhone
> On Aug 5, 2019, at 2:19 PM, Mark Rivers <[email protected]> wrote:
> It’s hard to see how a firewall could affect spec but not the shell caget command?
> Sent from my iPhone
>> On Aug 5, 2019, at 10:41 AM, Jennings, Guy via Tech-talk <[email protected]> wrote:
>> Try turning off the firewall on your pc
>>> On Aug 4, 2019, at 6:48 PM, Miceli, Antonino via Tech-talk <[email protected]> wrote:
>>> Hi,
>>> We have an EPICS areadetector soft IOC (AD core 3.6) running on a Debian PC for a Lambda detector. We are trying to control with spec, but spec's epics_caget commands return errors (e.g., "Not Connected"). When we run caget from the PC running spec, it works fine.
>>> Any suggestions? I know this is not a spec mailing list, but I figure this is the next best thing!
>>> Thanks,
>>> Nino
Re: spec epics_caget not working Johnson, Andrew N. via Tech-talk
spec epics_caget not working Miceli, Antonino via Tech-talk
Re: spec epics_caget not working Jennings, Guy via Tech-talk
Re: spec epics_caget not working Mark Rivers via Tech-talk
Prev: Re: spec epics_caget not working Mark Rivers via Tech-talk
Next: Re: spec epics_caget not working Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 05 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
