1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: spec epics_caget not working
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Jennings, Guy" <[email protected]>, "Rivers, Mark L." <[email protected]>
Cc: "Miceli, Antonino" <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Mon, 5 Aug 2019 20:12:33 +0000
That isn't possible, AFAIK the firewall rules only know that some packets are being sent between some local and remote IP address+port, it doesn't know what the program is that's doing that I/O. Both Spec and caget use the CA client library which will perform identically given the same set of EPICS_CA_* environment variables.
- Andrew
On 8/5/19 3:00 PM, Jennings, Guy via Tech-talk wrote:
Agreed - unless there is a firewall rule explicit to caget
Sent from my iPhone
On Aug 5, 2019, at 2:19 PM, Mark Rivers <[email protected]> wrote:
It’s hard to see how a firewall could affect spec but not the shell caget command?
Sent from my iPhone
On Aug 5, 2019, at 10:41 AM, Jennings, Guy via Tech-talk <[email protected]> wrote:
Try turning off the firewall on your pc
On Aug 4, 2019, at 6:48 PM, Miceli, Antonino via Tech-talk <[email protected]> wrote:
We have an EPICS areadetector soft IOC (AD core 3.6) running on a Debian PC for a Lambda detector. We are trying to control with spec, but spec's epics_caget commands return errors (e.g., "Not Connected"). When we run caget from the PC running spec, it works fine.
Any suggestions? I know this is not a spec mailing list, but I figure this is the next best thing!
Nino
Complexity comes for free, Simplicity you have to work for.
Re: spec epics_caget not working Michael Davidsaver via Tech-talk
spec epics_caget not working Miceli, Antonino via Tech-talk
Re: spec epics_caget not working Jennings, Guy via Tech-talk
Re: spec epics_caget not working Mark Rivers via Tech-talk
Prev: Re: spec epics_caget not working Jennings, Guy via Tech-talk
Next: Re: [EXTERNAL] updating ADAndor from RHEL6 to RHEL7 Pearson, Matthew R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: spec epics_caget not working Michael Davidsaver via Tech-talk
ANJ, 05 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
