On 8/5/19 1:12 PM, Johnson, Andrew N. via Tech-talk wrote:
> That isn't possible, AFAIK the firewall rules only know that some packets are being sent between some local and remote IP address+port, it doesn't know what the program is that's doing that I/O. Both Spec and caget use the CA client library which will perform identically given the same set of EPICS_CA_* environment variables.
Though it is likely not relevant in this case.
FYI. Linux iptables rules can consider sending process UID and GID.
cf. the --uid-owner match.
- spec epics_caget not working Miceli, Antonino via Tech-talk
- Re: spec epics_caget not working Jennings, Guy via Tech-talk
- Re: spec epics_caget not working Mark Rivers via Tech-talk
- Re: spec epics_caget not working Johnson, Andrew N. via Tech-talk
Re: Question about EPICS7 + QSRV Michael Davidsaver via Tech-talk
Re: [motorPIGCS2] can't turn on servo state of PI E-712 Peterson, Kevin M. via Tech-talk
<2019>
2025
2026
Question about EPICS7 + QSRV Florian Feldbauer via Tech-talk
<2019>
2025
2026
ANJ, 06 Aug 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
