1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record
From: Florian Feldbauer via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Mon, 12 Aug 2019 14:57:55 +0200
Thanks for the answer,
this explains the behavior of the mbbi direct record, but for the bi record / checkbox I do not have set DTYP
and still it only works by using ".RVAL" in the record name.
Cheers,
Florian
On 8/12/19 2:31 PM, Kasemir, Kay wrote:
Hi:
It's about the DTYP. When I take the DTYP line out:
>   field( DTYP, "Raw Soft Channel")
.. it works OK.
When I add the Raw Soft Channel, it doesn't.
But then I cannot change it from a command line "caput ..ToT 1" either.
So this is unrelated to the CA client (command line caput, phoebus, ...) and instead a feature of the IOC database and the Raw Soft Channel support.
When you select Raw Soft Channel, you need to write the RVAL.
.. but then that's just a number, no longer an enum, so you cannot use "Items from PV" on the widget.
--> Remove the DTYP.
-Kay
From: [email protected] <[email protected]> on behalf of Florian Feldbauer via Tech-talk <[email protected]>
Sent: Monday, August 12, 2019 2:40 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record
Hey all,
in a test setup I'm currently using base 7.0.2.2 and Phoebus (commit
ff6d0dc4).
Now I have some bi and mbbi records like this:
> record( mbbi, "PANDA:LMD:MUPIX:TELESCOPE:L$(LAYER):ToT" ) {
>   field( ZRST, "ToT" )
>   field( ONST, "2Thres" )
>   field( TWST, "Ramp")
>   field( ZRVL, "0" )
>   field( ONVL, "2" )
>   field( TWVL, "1" )
> record( bi, "PANDA:LMD:MUPIX:TELESCOPE:L$(LAYER):bandgap1" ) {
>   field( ZNAM, "disabled" )
>   field( ONAM, "active" )
For the mbbi record I'm using the Radiobutton widget and for the bi the
checkbox widget.
I tried CA as well as PVaccess (PV name "PANDA:..." and "pva://PANDA:...)
In both cases I cannot change the value of the records. The checkbox
only works if I explicitly append ".RVAL" to the
PV name. The Radiobutton does nothing. Is this behavior expected or am I
doing something wrong?
Best regards,
Florian
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Phoebus Radiobutton cannot set mbbi record Florian Feldbauer via Tech-talk
Prev: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
