Hi Florian,
If your cross-complier is based on the Yocto project, please look at
three configuration files in [1]. Especially, linux-corei7-poky one may
contains more explanation how the cc configuration shell script can be
converted into the EPICS base configuration file. If you need more help,
I may look at my personal log how to do this later.
You may need the similar your own configuration file instead of the
standard EPICS base ones.
You have to create your own configuration in order to override
* GNU_DIR
* GNU_BIN
* GNU_TARGET_LIB_DIR
I don't have time to submit them to the community, at the same time,
they contains the site specific environment variables also.
HTH,
Han
[1] https://github.com/icshwi/e3-base/tree/master/configure/os
https://github.com/icshwi/e3-base/blob/master/configure/os/CONFIG_SITE.Common.linux-ppc64e6500
On 8/30/19 1:17 PM, Florian Feldbauer via Tech-talk wrote:
Hey,
I have another problem with cross-compiling.
When compiling a hello world program with my cross-toolchain and
inspecting it with `file`, the interpreter is /lib/ld-linux-armhf.so.3.
When cross-compiling EPICS and inspecting the executable of my IOC, the
interpreter is /lib/ld-linux.so.3.
Does anyone know how I could fix this issue? For now I use a symlink on
my target system as a workaround:
> ln -s /lib/ld-linux-armhf.so.3 /lib/ld-linux.so.3
But it would of course be better if this workaround would not be needed
at all.
Another question: When deploying the IOC to my target system, the path
is not necessarily the same as the building path anymore.
So, when I start my IOC, I get the following warning:
Warning: IOC is booting with TOP = "/opt/epics"
but was built with TOP = "/home/florian/epics/iocs/test-ioc"
Is there anyway to get rid of this warning?
Best regards,
Florian
On 8/29/19 9:43 PM, Florian Feldbauer via Tech-talk wrote:
Hey Andrew,
just when your mail arrived, I was looking through the output of make
and found a line, where g++ was used for compiling using the correct
flags. Like you said...
I now replaced USR_CFLAGS by ARCH_DEP_CFLAGS and added
ARCH_DEP_LDFLAGS +=
--sysroot=/opt/iseg/cross-compiler/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi
Now it works! Thanks for your help!
Cheers,
Florian
On 8/29/19 9:23 PM, Johnson, Andrew N. via Tech-talk wrote:
Hi Florian,
On 8/29/19 1:33 PM, Florian Feldbauer via Tech-talk wrote:
My configure/os/CONFIG_SITE.linux-x86-64.linux-arm looks like this
GNU_TARGET = arm-angstrom-linux-gnueabi
GNU_BIN =
/opt/cross-compiler/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi
COMMANDLINE_LIBRARY = READLINE_NCURSES
USR_CFLAGS += -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
USR_CXXFLAGS += -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
Looking at the compiler commands executed by make below, only the
USR_CFLAGS are used when compiling c files, but the CXXFLAGS are
ignored.
USR_CFLAGS is used when compiling .c files to .o
USR_CXXFLAGS is used when compling .cpp/.cxx/.cc flags to .o
USR_LDFLAGS is used when linking .o files together into executables
or libraries.
It's the latter (link) stage that is failing in your build. Your
first command is a compilation of a C file, which succeeds:
/opt/iseg/cross-compiler/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gcc
-D_GNU_SOURCE -D_DEFAULT_SOURCE -march=armv7-a -mthumb
-DUNIX -Dlinux -O3 -g -Wall -march=armv7-a -mthumb
-fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc
-I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux
-I../../src/osi/os/posix -I../../src/osi/os/default -I..
-I../../src/as -I../../src/bucketLib -I../../src/calc
-I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates
-I../../src/dbmf -I../../src/ellLib -I../../src/env
-I../../src/error -I../../src/fdmgr -I../../src/flex
-I../../src/freeList -I../../src/gpHash -I../../src/iocsh
-I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi
-I../../src/pool -I../../src/ring -I../../src/taskwd
-I../../src/timer -I../../src/yacc -I../../src/yacc
-I../../src/yajl -I/opt/epics/base/include/compiler/gcc
-I/opt/epics/base/include/os/Linux -I/opt/epics/base/include
-I/opt/epics/base/include -c ../../src/yajl/yajl_parser.c
The next command is actually using g++ to link object files into a
library (libCom.so.3.17.5), it isn't actually compiling anything, so
it doesn't get given your $(USR_CXXFLAGS):
/opt/iseg/cross-compiler/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-g++
-o libCom.so.3.17.5 -shared -fPIC -L/opt/epics/base/lib/linux-arm
-Wl,-rpath,/opt/epics/base/lib/linux-arm -rdynamic asLib.o
asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o
resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o
envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o
fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o
registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o
macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o
epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o
truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o
epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o
epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o
osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o
systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o
osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o
epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o
osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o
osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o
osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o
osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o
epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o
timerQueue.o timerQueueActive.o timerQueueActiveMgr.o
timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o
yajl_gen.o yajl_lex.o yajl_parser.o -lpthread -lreadline
-lncurses -lm -lrt -ldl -lgcc
The last command breaks because the --sysroot option is missing and
the compiler doesn't find it's libraries.
Did I do something wrong? What is the correct way to define default
C compiler and C++ compiler flags when cross-compiling?
You didn't set a variable to provide the linker flags needed for your
build. Following your other settings that would be USR_LDFLAGS, but I
would recommend that you actually set these variables instead:
ARCH_DEP_CFLAGS = <your USR_CFLAGS value above>
The ARCH_DEP_CXXFLAGS variable defaults to $(ARCH_DEP_CFLAGS) so you
don't need to set this at all.
ARCH_DEP_LDFLAGS = <flags to pass to g++ when using it as a linker>
I'm suggesting you use the ARCH_DEP_ flags instead of the USR_ ones
because some application Makefiles may override the USR_ variables
instead of just appending to them, which would cause your builds to
fail.
Hope this helps,
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: Cross compiling Florian Feldbauer via Tech-talk
- Cross compiling Florian Feldbauer via Tech-talk
- Re: Cross compiling Johnson, Andrew N. via Tech-talk
Re: Sumo test Goetz Pfeiffer via Tech-talk
RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it Abdalla Ahmad via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 01 Sep 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
