1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems compiling base-3.15.6 with RTEMS
From: Michael Westfall via Tech-talk <[email protected]>
Date: Fri, 13 Sep 2019 11:58:20 -0300
Going back to a previous version of EPICS (R3.14.12.8) I see I have the same problem when compiling, but it's only a warning, not an error, which is probably why I hadn't noticed it before.
/gem_sw/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_sw/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/mvme2307/lib/ -specs bsp_specs -qrtems   -fasm -c   -mcpu=604 -mmultiple -mstring -mstrict-align -meabi                   -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL -DHAVE_PPCBUG -DNVRAM_INDIRECT     -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include         ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c
../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:26:24: warning: bsp/bspExt.h: No such file or directory
../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c: In function 'rtemsDevInit':
../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:129: warning: implicit declaration of function 'bspExtInit'
On Fri, Sep 13, 2019 at 10:55 AM Michael Westfall <[email protected]> wrote:
Yes, libbspExt is already installed.
EPICS R3.14.12.8 (and previous versions) find it without any problem.
It's just EPICS R3.15.6 that can't find it for some reason.
acc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c
> ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:26:24: error: bsp/bspExt.h: No such file or directory
> make[3]: *** [devLibVMEOSD.o] Error 1
> make[3]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom/O.RTEMS-mvme3100'
> make[2]: *** [install.RTEMS-mvme3100] Error 2
> make[2]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src'
> make: *** [src.install] Error 2
> It can't find the header file for libbspExt in <bsp/bspExt.h>, even though it's right there where it's always been and can be found when compiling our previoous versions of EPICS...
> I've looked at all the files in .../base/configure, but I don't see what has changed that might cause this.
> Any pointers appreciated.
> Mike Westfall
> Control Systems Software Engineer
Mike Westfall
Re: Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
Re: Problems compiling base-3.15.6 with RTEMS Heinz Junkes via Tech-talk
Prev: Re: Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
Next: Re: Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 13 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
