> I need to set the PV value using CSS. The value is a DoubleArray and I'm using "pvs[1].setValue(array)" but the PV vaule is always null.
Not sure what exact type you mean by DoubleArray.
Do you actually mean org.diirt.util.array.ArrayDouble? Or plain java double[] ?
To be sure, print the type like this to the console:
value = ... however you get the value
print(value.__class__.__type__)
Anyway, the types accepted by the CA PV are the basic java scalar and array types, i.e. you need a double[].
They don't accept a jython list (org.python.core.PyList), which is what Jython will auto-create for you when you assemble the array in Jython, or whatever you would get from Javascript.
https://www.jython.org/archive/21/docs/jarray.html explains how to create a plain java array in jython.
Example script:
# pvs[1]: some waveform PV [NO TRIGGER!]
import jarray
python_array = [ 1, 2, 3, 4]
# Create java int[] or double[] array. Use 'i' for int, 'd' for double
arr = jarray.array(python_array, 'd')
# Now we can write to the PV
pvs[1].setValue(arr)
- Control System Studio (CSS) and PV Adrian martinez munera via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Mark Rivers via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
<2019>
2025
2026
EK9000 Device Support Lorelli, Jeremy J via Tech-talk
<2019>
2025
2026
