1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areaDetector compile problem with ffmpegServer step
From: Michael Westfall via Tech-talk <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Tue, 8 Oct 2019 17:36:28 -0300
Ah, I see there is a shell script that needs to be run manually in the ffmpegServer subdirectory..
Thanks...
On Tue, Oct 8, 2019 at 11:59 AM J. Lewis Muir <[email protected]> wrote:
On 10/08, Michael Westfall via Tech-talk wrote:
> My areaDetector compilation failed when it was compiling the ffmpegServer
> submodule with the following: I wonder what did I forget to do... It's
> looking for a a 'yasm' directory under 'vendor', but that doesn't exist.
You have to download and extract the Yasm distfile.  There are other
things you need too.
See
  https://github.com/areaDetector/ffmpegServer/blob/master/install.sh
Mike Westfall
Control Systems Software Engineer
areaDetector compile problem with ffmpegServer step Michael Westfall via Tech-talk
Re: areaDetector compile problem with ffmpegServer step J. Lewis Muir via Tech-talk
Prev: Re: comparison of different CA clients: caproto and pyepics Valentyn Stadnytskyi via Tech-talk
Next: few questions on autosave Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areaDetector compile problem with ffmpegServer step J. Lewis Muir via Tech-talk
Next: comparison of different CA clients: caproto and pyepics Valentyn Stadnytskyi via Tech-talk
ANJ, 10 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
