1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: No TCP server started
From: Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Tue, 29 Oct 2019 17:25:55 +0000
I've several soft IOCs happily running 7.0.3 on linux-x86_64 on different ports.  However,
I have a new one which is connected to a ethernet<->serial converter which runs
without issue from a terminal, but fails with "No TCP server started" when started
from procServ.  A similar message was reported to core-talk by Heinz Junkes when
using 3.16.0.1-DEV-fhi.
This has nothing to do with my databases, as I have them commented out:
My startup command is:
epics:~/epicsDEV/Config/ProcLauncher> procServ -i ^D^C --killsig 15 --logfile /home/epics/epicsDEV/ioc_logs/Keithley2700_2019_10_29__11_59_38.log --name Keithley2700 --pidfile /home/epics/.PROCSERV_CMD_1572368378214534208 --quiet 7718 /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd
And the resulting log file has:
@@@ Restarting child "Keithley2700"
@@@    (as /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd)
@@@ The PID of new child "Keithley2700" is: 7855
#!../../bin/linux-x86_64/Keithley2700
## You may have to change Keithley2700 to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","iocKeithley2700")
epicsEnvSet("TOP","/home/epics/epicsDEV/iocTops/Multimeter")
epicsEnvSet("EPICS_BASE","/home/epics/epicsDEV/base")
epicsEnvSet("EPICS_SUPPORT","/home/epics/epicsDEV/Support")
epicsEnvSet("ASYN","/home/epics/epicsDEV/Support/asyn")
epicsEnvSet("CALC","/home/epics/epicsDEV/Support/calc")
epicsEnvSet("STREAM","/home/epics/epicsDEV/Support/StreamDevice")
epicsEnvSet("ALIVE","/home/epics/epicsDEV/Support/alive")
epicsEnvSet("KEITHLEY","/home/epics/epicsDEV/Support/Keithley")
epicsEnvSet("EPICS_IOC_OWNER","hanlet")
epicsEnvSet("EPICS_IOC_GROUP","FE_group")
epicsEnvSet("EPICS_IOC_LOCATION","???")
cd "/home/epics/epicsDEV/iocTops/Multimeter"
dbLoadDatabase "dbd/Keithley2700.dbd"
Keithley2700_registerRecordDeviceDriver pdbbase
## Configure IP port
drvAsynIPPortConfigure("keithley","131.225.138.251:10002",0,0,0)
## Debuggin
asynSetTraceIOMask("keithley",0,2)
asynSetTraceMask("keithley",0,9)
## Load record instances
#dbLoadRecords("db/Keithley2700.db")
#dbLoadRecords("db/alive.db")
#dbLoadRecords("db/watcher.db")
## Protocol file
epicsEnvSet("STREAM_PROTOCOL_PATH","/home/epics/epicsDEV/Support/Keithley/Keithley2700App/protocol")
## Start IOC
cd "/home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700"
iocInit
Starting iocInit
## EPICS R7.0.3
## EPICS Base built Oct 23 2019
CAS: No TCP server started
Thread _main_ (0x1b50450) can't proceed, suspending.
Dumping a stack trace of thread '_main_':
[    0x7fc82a4fe25b]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(epicsStackTrace+0x4b)
[    0x7fc82a4ee818]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(cantProceed+0xb8)
[    0x7fc82a9f4be9]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(rsrv_init+0xf69)
[    0x7fc82a9e07ab]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(dbInitServers+0x1b)
[    0x7fc82a9f19de]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocBuild+0x2e)
[    0x7fc82a9f1b89]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocInit+0x9)
[    0x7fc82a4e9555]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(iocshBody+0xb15)
[          0x407bb2]: ../../bin/linux-x86_64/Keithley2700(main+0x12)
[    0x7fc828d64545]: /lib64/libc.so.6(__libc_start_main+0xf5)
[          0x407bfd]: ../../bin/linux-x86_64/Keithley2700(_start+0x29)
Any ideas?  If helpful, the device is a Lantronix UDS2100 serial-to-ethernet converter; though I
don't know if that matters.
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: No TCP server started Heinz Junkes via Tech-talk
Re: No TCP server started Michael Davidsaver via Tech-talk
Prev: Re: building synApps from Git Lang, Keenan C. via Tech-talk
Next: Re: No TCP server started Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building synApps from Git Mark Rivers via Tech-talk
ANJ, 31 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
