1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS support for Eurotherm 3508.
Date: Wed, 30 Oct 2019 20:47:32 +0000
We got an FMB hot air blower based on Eurotherm 3508. We have the old model with Eurotherm 2408, and it seems its IOC doesn't work with the new one. Has anyone created EPICS support for 3508? Thanks.
Best,
-Ji Li
发件人: Tech-talk <[email protected]> 代表 [email protected] <[email protected]>
发送时间: 2019年10月30日 13:00:02
收件人: [email protected] <[email protected]>
主题: Tech-talk Digest, Vol 13, Issue 434
Send Tech-talk mailing list submissions to
        [email protected]
To subscribe or unsubscribe via the World Wide Web, visit
        https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
        [email protected]
You can reach the person managing the list at
        [email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. Re: No TCP server started (Pierrick M Hanlet)
Message: 1
Date: Wed, 30 Oct 2019 16:26:42 +0000
To: Heinz Junkes <[email protected]>
Subject: Re: No TCP server started
Message-ID: <[email protected]>
Content-Type: text/plain; charset="utf-8"
Hi Heinz,
Thanks for the response.? I suspect that it may not be so much a problem
with
EPICS base as with my configuration of the ethernet<->serial converter
since I
have a number of other soft IOCs running on different ports of the same
machine.
What I really don't understand is why it is different when the process
is started from
procServ.
Thanks again,
Pierrick
On 10/29/19 1:07 PM, Heinz Junkes wrote:
> I found in my mails  to Michael Davidsaver:
> "can confirm that with
> ## EPICS R3.16.1-DEV
> this problem has been fixed?
> Is it possible that a patch was not adopted for 7.0.3?
> I'm going to investigate ? Heinz
>> On 29. Oct 2019, at 18:25, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
>> Hi,
>> I've several soft IOCs happily running 7.0.3 on linux-x86_64 on different ports.  However,
>> I have a new one which is connected to a ethernet<->serial converter which runs
>> without issue from a terminal, but fails with "No TCP server started" when started
>> from procServ.  A similar message was reported to core-talk by Heinz Junkes when
>> using 3.16.0.1-DEV-fhi.
>> This has nothing to do with my databases, as I have them commented out:
>> My startup command is:
>> epics:~/epicsDEV/Config/ProcLauncher> procServ -i ^D^C --killsig 15 --logfile /home/epics/epicsDEV/ioc_logs/Keithley2700_2019_10_29__11_59_38.log --name Keithley2700 --pidfile /home/epics/.PROCSERV_CMD_1572368378214534208 --quiet 7718 /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd
>> And the resulting log file has:
>> @@@ Restarting child "Keithley2700"
>> @@@    (as /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd)
>> @@@ The PID of new child "Keithley2700" is: 7855
>> #!../../bin/linux-x86_64/Keithley2700
>> ## You may have to change Keithley2700 to something else
>> ## everywhere it appears in this file
>> < envPaths
>> epicsEnvSet("IOC","iocKeithley2700")
>> epicsEnvSet("TOP","/home/epics/epicsDEV/iocTops/Multimeter")
>> epicsEnvSet("EPICS_BASE","/home/epics/epicsDEV/base")
>> epicsEnvSet("EPICS_SUPPORT","/home/epics/epicsDEV/Support")
>> epicsEnvSet("ASYN","/home/epics/epicsDEV/Support/asyn")
>> epicsEnvSet("CALC","/home/epics/epicsDEV/Support/calc")
>> epicsEnvSet("STREAM","/home/epics/epicsDEV/Support/StreamDevice")
>> epicsEnvSet("ALIVE","/home/epics/epicsDEV/Support/alive")
>> epicsEnvSet("KEITHLEY","/home/epics/epicsDEV/Support/Keithley")
>> epicsEnvSet("EPICS_IOC_OWNER","hanlet")
>> epicsEnvSet("EPICS_IOC_GROUP","FE_group")
>> epicsEnvSet("EPICS_IOC_LOCATION","???")
>> cd "/home/epics/epicsDEV/iocTops/Multimeter"
>> ## Register all support components
>> dbLoadDatabase "dbd/Keithley2700.dbd"
>> Keithley2700_registerRecordDeviceDriver pdbbase
>> ## Configure IP port
>> drvAsynIPPortConfigure("keithley","131.225.138.251:10002",0,0,0)
>> ## Debuggin
>> asynSetTraceIOMask("keithley",0,2)
>> asynSetTraceMask("keithley",0,9)
>> ## Load record instances
>> #dbLoadRecords("db/Keithley2700.db")
>> #dbLoadRecords("db/alive.db")
>> #dbLoadRecords("db/watcher.db")
>> ## Protocol file
>> epicsEnvSet("STREAM_PROTOCOL_PATH","/home/epics/epicsDEV/Support/Keithley/Keithley2700App/protocol")
>> ## Start IOC
>> cd "/home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700"
>> iocInit
>> Starting iocInit
>> ## EPICS R7.0.3
>> ## EPICS Base built Oct 23 2019
>> CAS: No TCP server started
>> Thread _main_ (0x1b50450) can't proceed, suspending.
>> Dumping a stack trace of thread '_main_':
>> [    0x7fc82a4fe25b]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(epicsStackTrace+0x4b)
>> [    0x7fc82a4ee818]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(cantProceed+0xb8)
>> [    0x7fc82a9f4be9]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(rsrv_init+0xf69)
>> [    0x7fc82a9e07ab]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(dbInitServers+0x1b)
>> [    0x7fc82a9f19de]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocBuild+0x2e)
>> [    0x7fc82a9f1b89]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocInit+0x9)
>> [    0x7fc82a4e9555]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(iocshBody+0xb15)
>> [          0x407bb2]: ../../bin/linux-x86_64/Keithley2700(main+0x12)
>> [    0x7fc828d64545]: /lib64/libc.so.6(__libc_start_main+0xf5)
>> [          0x407bfd]: ../../bin/linux-x86_64/Keithley2700(_start+0x29)
>> Any ideas?  If helpful, the device is a Lantronix UDS2100 serial-to-ethernet converter; though I
>> don't know if that matters.
>> Thanks,
>> Pierrick
>> Pierrick Hanlet
>> Fermi National Accelerator
>> Accelerator Front End Controls
>> +1-630-840-5555 -- lab
>> +1-312-687-4980 -- mobile
>> "Whether you think you can or think you can't, you're right" -- Henry Ford
Pierrick Hanlet
Subject: Digest Footer
Tech-talk mailing list [email protected]
End of Tech-talk Digest, Vol 13, Issue 434
Re: EPICS support for Eurotherm 3508. Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: missing addRecord.h Johnson, Andrew N. via Tech-talk
Next: Re: Why should I care about breakpoint table monotonicity? Ernesto Paiser via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS support for Eurotherm 3508. Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
ANJ, 04 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
