Hi Andrew,
I'm getting the same problem as Emmanuel:
Unknown option:b
I'm using EPICS 3.15.5:
I added in my Makefile:
DBEXPAND += -b
records_DBD += recordsBpt.dbd
Is this option still working in 3.15.5?
Thanks
Ernesto
Here the output:
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
T_A=linux-x86_64 install
make[1]: Entering directory
`/home/clsfs/epics/2/git/epics-iocs/cls1/drv/records/src/O.linux-x86_64'
Creating dbd file records.dbd
perl -CSD /opt/epics/base/bin/linux-x86_64/dbdExpand.pl -b -I
/home/local/epics/iochost/clsbpm1/dbd -I
/opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd -I
/opt/epics/extensions/synApps_6_1/support/StreamDevice-2-8-9/dbd -I
/opt/epics/extensions/synApps_6_1/support/calc-R3-7-3/dbd -I
/opt/epics/extensions/src/csm-4.5/dbd -I
/opt/epics/extensions/synApps_6_1/support/autosave-R5-10/dbd -I. -I..
-I../O.Common -I../../../dbd -I/opt/epics/base/dbd -o records.dbd
base.dbd asSupport.dbd recordsSupport.dbd
/opt/epics/extensions/synApps_6_1/support/calc-R3-7-3/dbd/calcSupport.dbd
/opt/epics/extensions/synApps_6_1/support/StreamDevice-2-8-9/dbd/stream.dbd
/opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd/asyn.dbd
/opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd/drvAsynIPPort.dbd
/opt/epics/extensions/synApps_6_1/support/asyn-R4-36/dbd/drvAsynSerialPort.dbd
/opt/epics/extensions/src/csm-4.5/dbd/cvtRecord.dbd recordsBpt.dbd
Unknown option: b
Usage: dbdExpand [-D] [-I dir] [-S macro=val] [-o out.dbd] in.dbd ... at
/opt/epics/base/bin/linux-x86_64/dbdExpand.pl line 20.
make[1]: *** [../O.Common/records.dbd] Error 255
make[1]: Leaving directory
make: *** [install.linux-x86_64] Error 2
Ernesto Paiser
Senior Controls Software Engineer
Lyncean Technologies, Inc.
47633 Westinghouse Drive
Fremont, CA 94539
Phone: +1-650-320-8300 ext. 452
www.lynceantech.com
- Re: Why should I care about breakpoint table monotonicity? Andrew Johnson via Tech-talk
EPICS support for Eurotherm 3508. Li, Ji via Tech-talk
Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
<2019>
2025
2026
RE: EPICS support for Eurotherm 3508. Li, Ji via Tech-talk
<2019>
2025
2026
