1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Base-3.15.7 and EPICS 7.0.3.1 Released
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 1 Nov 2019 23:12:46 +0000
Two new releases of EPICS have been made and are now available for download from all the usual places. The following headlines from the Release Notes show the range of changes included in each version. Note that the EPICS 7 release also includes all of the changes in the 3.15 release:
EPICS 7.0.3.1:
  • logClient reliability
  • Timers and delays use monotonic clock
  • Iocsh on error ...
  • Relocatable Builds
  • Decouple LINKER_USE_RPATH and STATIC_BUILD
  • Channel Access Security: Check Hostname Against DNS
  • New and modified epicsThread APIs
  • Non-VME RTEMS targets now define pdevLibVME
  • Updates to the PVA modules too…
EPICS Base-3.15.7:
  • GNU Readline detection on Linux
  • Replace EPICS_TIMEZONE with EPICS_TZ
  • Added new decimation channel filter
  • Imported Record Reference Documentation from Wiki
  • make test-results for Windows
  • Add option to avoid CALLBACK conflict
  • Cleaning up with Multiple CA contexts in a Process
  • Perl CA bindings fixed for macOS Mojave
  • Routine epicsTempName() removed from libCom
  • DBD Parsing of Record Types
  • menuScan and several record types documented with POD
  • CA client tools learned -V option
Through the work of some hard-working volunteers who attended the Documentathon at ESS in September, these releases now come with Record Reference Documentation, converted from the text on the EPICS Wiki. You can also find those documents online for Base-3.15.7 and EPICS 7.0.3.1. The texts aren't guaranteed to be completely accurate yet, but we're getting there slowly!
The individual release pages with links to all of the above are here:
Thanks to everyone who contributed to the development work that made these releases possible.
- Andrew, for the EPICS Core Developers group.
Complexity comes for free, Simplicity you have to work for.
Re: EPICS Base-3.15.7 and EPICS 7.0.3.1 Released Williams Jr., Ernest L. via Tech-talk
Prev: RE: building synApps from Git Mark Rivers via Tech-talk
Next: Re: EPICS Base-3.15.7 and EPICS 7.0.3.1 Released Williams Jr., Ernest L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
ANJ, 08 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
