1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform record not sending monitor on .NORD field
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Lucas Russo <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 6 Nov 2019 09:19:38 -0800
On 11/6/19 4:48 AM, Lucas Russo via Tech-talk wrote:
> Hi again,
> As a workaround to the problem I FLNK'ed the "waveform" record to an "ai" record that fetches its .NORD value. The "ai" send the monitors correctly and I can monitor them from the other IOC.
This was a common workaround with Base 3.14.x, which shouldn't be necessary with later versions.
Between this, and better handling by CA of array size changes, I find it unnecessary these days.
waveformRecord was fixed in 3.15.0.1 by [1] and for other record types in Base
by [2] in 3.15.6 (also changes waveformRecord slightly to post a monitor only
when NORD changes).
[1] https://github.com/epics-base/epics-base/commit/037e5f6a9def88cc5e1422788999fe3299c24c31
[2] https://bugs.launchpad.net/epics-base/+bug/1730727
    https://github.com/epics-base/epics-base/commit/ec351c5e2f995770b3fc6788b63cf76990fbb2f3
> Cheers!
> Lucas
> On Thu, Oct 31, 2019 at 7:51 AM Lucas Russo <[email protected] <mailto:[email protected]>> wrote:
>     Hello everyone,
>     I've been trying to use the .NORD field value to trigger a change in a subArray record. I'm doing it like this: https://github.com/lnls-dig/tune-epics-ioc/blob/master/tuneApp/Db/tune.db#L519
>     And the waveform I'm monitoring from is this one: https://github.com/lnls-dig/rsfsx-epics-ioc/blob/master/rsfsxApp/Db/rsfsx.db#L1670
>     I can see that the Trace-Mon record is correctly sending monitors on the .VAL field. Also, the value of .NORD changes correctly as well, but it's just not sending any monitors (tested with camonitor).
>     I'm using epics base 3.15.5. From the release notes it seems this has been fixed in 3.15.0.1.
>     Am I missing something here?
>     Thanks a lot!
>     Lucas
Re: Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
Prev: Re: init a waveform Johnson, Andrew N. via Tech-talk
Next: RE: Streamdevice segmentation fault Brown, Garth via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
Next: Re: Waveform record not sending monitor on .NORD field Lucas Russo via Tech-talk
ANJ, 07 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
