1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: init a waveform
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Alfio Rizzo <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 6 Nov 2019 16:30:09 +0000
On 11/6/19 9:26 AM, Alfio Rizzo via Tech-talk wrote:
I was wondering if there is a way to fill with some initial values a waveform record in a db file,
I.e. something like
record (waveform,mywave){
  field(VAL,”X Y Z”)
Yes, if you are using a recent EPICS 7 then you can initialize it using an array constant link like this:
record(waveform, wf100:i16) {
  field(FTVL, "SHORT")
  field(NELM, "100")
  field(INP, [1, 2, 3, 4, 5])
I forget exactly which version you need to be on (maybe 7.0.2), it doesn't have to be the version that just came out though.
- Andrew
Complexity comes for free, Simplicity you have to work for.
init a waveform Alfio Rizzo via Tech-talk
Prev: init a waveform Alfio Rizzo via Tech-talk
Next: Re: Waveform record not sending monitor on .NORD field Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: rmt CCExecInit problem Tasaddaq Khan via Tech-talk
ANJ, 07 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
