Thx I will look into that. I am using EPICS for a cyber security demo, as my avionics data handler. Our needs here are quite different then the accelerators, so I dont know if its worth the effort. My system is hacked together from what I remembered from using at jlab. However if it gets traction here, other groups here may be interested.
thx
Thad
Sent: Thursday, November 07, 2019 3:23 PM
To: Seeberger, John T CIV USN NAS PAX MD (USA); Rivers, Mark L.; Kasemir, Kay
Cc: [email protected]
Subject: [Non-DoD Source] Re: Serial port bus connection issue on arm platform
On 11/7/19 12:01 PM, Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk wrote:
One thing I was wondering would there be away to build and have both linux-arm32, and linux-arm64 platforms. Rather then just linux-arm.
EPICS Base allows you to create your own local target architectures based on the build configuration of another existing architecture. The easiest way to show this is to look in the base/configure/os directory at the *.linux-arm_eb* or *.linux-arm_el* files, which include the linux-arm target files and then override some settings.
You could create files for say linux-aarch64; you just need to ensure that you have the environment variable EPICS_HOST_ARCH set to that on your aarch64 system since our EpicsHostArch.pl script doesn't currently know how to distinguish that. I would be happy to add such configuration files (and any modifications to the EpicsHostArch.pl script) to Base if you can offer them.
HTH,
- Andrew
From: Mark Rivers [[email protected]<mailto:[email protected]>]
Sent: Thursday, November 07, 2019 11:37 AM
To: Seeberger, John T CIV USN NAS PAX MD (USA); Kasemir, Kay
Cc: [email protected]<mailto:[email protected]>
Subject: [Non-DoD Source] RE: Serial port bus connection issue on arm platform
Hi Thad,
The answer is in your original post.
You showed this output:
dbior "stream"
Driver: stream
StreamDevice 2.7.7 built Oct 24 2019 13:43:29
registered bus interfaces:
DebugInterface
DummyInterface
I get this output on my system:
epics> dbior "stream"
Driver: stream
StreamDevice 2.8.STREAM_PATCHLEVEL built Nov 2 2019 14:06:26
AsynDriverInterface
DebugInterface
DummyInterface
Note that you are missing the AsynDriverInterface. So the problem appears to be the way your built stream. Please check the stream/configure/RELEASE file, etc.
-----Original Message-----
From: Tech-talk <[email protected]><mailto:[email protected]> On Behalf Of Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Sent: Thursday, November 7, 2019 10:26 AM
To: Kasemir, Kay <[email protected]><mailto:[email protected]>
Cc: Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk <[email protected]><mailto:[email protected]>
Subject: RE: Serial port bus connection issue on arm platform
Works fine on the aarch64 and x86 version, so I'd say no.
Thad
From: Tech-talk [[email protected]<mailto:[email protected]>] on behalf of Kasemir, Kay via Tech-talk [[email protected]<mailto:[email protected]>]
Sent: Thursday, November 07, 2019 11:17 AM
To: Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Just a silly idea: Is "SERIALPORT" simply too long for the stream device? I've mostly seen examples like "P1" for ports.
2019/11/07 16:04:56.709466 _main_ Cannot find a bus named 'SERIALPORT' for 'aoa'
Complexity comes for free, Simplicity you have to work for.
- Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
- Re: Serial port bus connection issue on arm platform Johnson, Andrew N. via Tech-talk
- RE: Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
- Re: Serial port bus connection issue on arm platform Kasemir, Kay via Tech-talk
- RE: Serial port bus connection issue on arm platform Mark Rivers via Tech-talk
Re: Connection Timeout Using Asyn and StreamDevice with Ethernet Device Peterson, Kevin M. via Tech-talk
ADAndor iKon CCD low saturation point Pearson, Matthew R. via Tech-talk
<2019>
2025
2026
Connection Timeout Using Asyn and StreamDevice with Ethernet Device Kyle Hesse via Tech-talk
<2019>
2025
2026
