On 12/1/19 4:07 AM, Heinz Junkes wrote:
Hello, Marty,
thank you for wanting to take care of this.
A question on the side:
Is there a reason why you can't call also int's and long's directly?
There is no
getInt, putInt, getLong, putLong, getIntArray, putIntArray, getLongArray, putLongArray etc.
Or did I miss something?
This means byte, short, ubyte, ushort, uint, ulong, and float.
Note that double does work for all the numeric types.
The other types are converted to from double.
My thought was to provide the most useful convenience methods.
If someone really want to use any of the integer types they must do more
work.
Marty
Danke, Heinz
On 30. Nov 2019, at 16:58, Marty Kraimer via Tech-talk <[email protected]> wrote:
You are correct that the code for puts only works on a top level field named value.
A new issue has been created.
https://github.com/epics-base/pvaClientCPP/issues/63
Marty
On 11/28/19 11:12 AM, Heinz Junkes via Tech-talk wrote:
According the documentation to Release 4.5.0 :
Changes have been made for getDouble, putDouble, getDoubleArray, putDoubleArray, getString, putString, getStringArray, and putStringArray.
1) Previously each only had support for a top level field named value. Each now allows access to a single sub field that has the correct type. Thus pvRequest must select a single field. For example
pva->channel("PVRdumbPowerSupply")->putDouble(1.0,"power.value" );
I try to access a double array but with no success:
string channelName("CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK");
string providerName("pva");
PvaClientPtr pva = PvaClient::get(providerName);
pva->channel(channelName, providerName, 1.0)->putDoubleArray(freeze(valx), "value.column0");
error message:
2019/11/28 10:06:17.754 sis0: void Sis3316Port::updateTask(): PvaClientData::putDoubleArray() did not find a scalarArray field
Command line works:
[junkes@h epics]$ pvget -r "value.column0" CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK structure
structure value
double[] column0 []
How can I address the DoubleArray?
Danke Heinz
- pvaClientCPP Release 4.5.0 access to a single sub field that has the correct type Heinz Junkes via Tech-talk
- Re: pvaClientCPP Release 4.5.0 access to a single sub field that has the correct type Marty Kraimer via Tech-talk
- Re: pvaClientCPP Release 4.5.0 access to a single sub field that has the correct type Heinz Junkes via Tech-talk
Re: lsi record for more than 40 characters doesn't work Ralph Lange via Tech-talk
<2019>
2025
2026
lsi record for more than 40 characters doesn't work dmnr infn via Tech-talk
<2019>
2025
2026
