1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: lsi record for more than 40 characters doesn't work
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Sun, 1 Dec 2019 12:17:16 +0100
Your database and protocol look fine.
Why do you think you are only getting 40 characters? Have you checked the lsi record's contents from the iocShell? Have you checked its LEN field? Have you switched on debugging for StreamDevice and/or ASYN?
If you are reading your string over Channel Access, note that the CA string type is limited to 40 characters. For longer strings, your application will have to fetch the value as an array of characters (by adding the '$' tag to the channel name) and convert that array to a string. The command line 'caget' for your lsi record would be:
caget -S RF:getString.VAL$
Cheers,
~Ralph
On Sun, 1 Dec 2019 at 05:44, dmnr infn via Tech-talk <[email protected]> wrote:
Hi all,
I have a .db e .proto made in this way:
.db
record(lsi, "RF:getString")
    field(DESC, "String more than 40 chars")
    field(SIZV, "80")
    field(INP, "@MDO.proto getString L0")
    field(SCAN, ".2 second")
.proto
getString {
    out "STT?";
    in "%s";
I want to get a String that is more than 40 characters, and I use a lsi record but I got always 40 chars.
There is something wrong in my code?
Thank you
lsi record for more than 40 characters doesn't work dmnr infn via Tech-talk
Prev: Re: pvaClientCPP Release 4.5.0 access to a single sub field that has the correct type Marty Kraimer via Tech-talk
Next: ADAndor and the Ikon-M Koennecke Mark (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: lsi record for more than 40 characters doesn't work Johnson, Andrew N. via Tech-talk
Next: Re: lsi record for more than 40 characters doesn't work Eric Norum via Tech-talk
ANJ, 02 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
