1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: lsi record for more than 40 characters doesn't work
To: dmnr infn <[email protected]>
Cc: [email protected], [email protected]
Date: Mon, 2 Dec 2019 08:07:24 -0800
Others have dealt with the original question, but I’d like to add a followup.
Conversion strings like the one shown in the original message are unsafe and should never be used.  They can lead to buffer overflows and weird IOC behaviour.
The capacity of the destination buffer should always be specified.  Here, from the ASYN streamSCPI template, are the ’short’ and ‘long’ string versions of records to read SCPI identification strings:
record(stringin, "$(P)$(R)IDN")
    field(DESC, "SCPI identification string")
    field(DTYP, "stream")
    field(INP,  "@dev_NAME_.proto getIDN(39) $(PORT) $(A)")
    field(PINI, "YES")
record(waveform, "$(P)$(R)IDNwf")
    field(INP,  "@dev_NAME_.proto getIDN(199) $(PORT) $(A)")
    field(PINI, "YES")
    field(FTVL, "CHAR")
    field(NELM, "200")
getIDN {
    out "*IDN?";
    in "%\$1[^\r\n]";
    ExtraInput = Ignore;
On Nov 29, 2019, at 12:11 PM, dmnr infn via Tech-talk <[email protected]> wrote:
Hi all,
I have a .db e .proto made in this way:
.db
record(lsi, "RF:getString")
    field(DESC, "String more than 40 chars")
    field(SIZV, "80")
    field(INP, "@MDO.proto getString L0")
    field(SCAN, ".2 second")
.proto
getString {
    out "STT?";
    in "%s";
I want to get a String that is more than 40 characters, and I use a lsi record but I got always 40 chars.
There is something wrong in my code?
Thank you
Eric Norum
[email protected]
“Ah, the chance to be pedantic first thing on a Monday morning — what a great way to start the week."
Re: lsi record for more than 40 characters doesn't work Zimoch Dirk (PSI) via Tech-talk
lsi record for more than 40 characters doesn't work dmnr infn via Tech-talk
Prev: ADAndor and the Ikon-M Koennecke Mark (PSI) via Tech-talk
Next: Re: lsi record for more than 40 characters doesn't work Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: lsi record for more than 40 characters doesn't work Ralph Lange via Tech-talk
ANJ, 02 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
