I wish to report on getting our Andor Ikon-M USB camera to work with ADAndor. It is working now, but there was some pain involved. The environment: Linux SL6, 32 bit. We have a custom Andor library with an extra bulb mode. Thus we cannot change this. ADAndor is 2.8, the other components were selected to be about contemporary to the ADAndor release. I attach a trace for the details. My findings: 1.) The biggest stumbling block was that the shutter never got configured properly. The reason being that the driver throws some „parameter not found“ errors, especially with the shutter mode. Needless to say: I never messed with ADAndors parameter system, so I am pretty sure that I did not introduce the problem. I hacked that by placing a suitable call into startAcquisition(). 2.) All the gain logic is wasted on the Ikon-M. The speed logic seems faulty. 3.) There is a missing parameter though: that is the VSAmplitude. I hard coded that one because I believe we only use one setting for that. I am aware that this is no general solution. 4.) What is also missing is the SetShutterEx() support. Some of these cameras apparently support an external shutter. This would require another parameter to control that one. 5.) In my quest to get it working, I disabled some settings which I did not need and added what did not work. I attach my version of andorCCD.cpp. My (unprofessional) changes are marked up with MK in comments. 6.) Another thing which tripped me up was that the shutter opening and closing times were in seconds. Not in milliseconds as all the Andor documentation states. I only realized that when I found a 20000 in the trace where I expected a 20. I suggest to improve the documentation or at least set the EGU field in the DB. Best Regards, Mark Koennecke Attachment:
andortrace.log Attachment:
andorCCD.cpp
| ANJ, 03 Dec 2019 |
Home
News
About
Talk
Base
Modules
Extensions
