1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Linker error with vendor library
To: tech-talk <[email protected]>
Date: Sat, 7 Dec 2019 03:24:26 +0000
Folks,
I am trying to build the EPICS Xspress3 driver.  It builds fine on Centos 7 with gcc 4.5
On Ubuntu 18 with gcc 7.4 I get this error:
/usr/bin/ld: /corvette/home/epics/devel/areaDetector-3-8/xspress3-2-2/lib/linux-x86_64-ub18/libimg_mod.a(img_mod_linux.o): relocation R_X86_64_32 against `.rodata' can not be used when making a PIE object; recompile with -fPIC
/usr/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
/corvette/usr/local/epics-devel/base-7.0.3.1/configure/RULES_BUILD:212: recipe for target 'xspress3App' failed
make[1]: *** [xspress3App] Error 1
libimg_mod.a is a pre-built library provided by the vendor.  Is there something I can change in the link options to avoid this error, or do we need to get a new library from the vendor?
Re: Linker error with vendor library Michael Davidsaver via Tech-talk
Prev: Re: Record for a running sum Hu, Yong via Tech-talk
Next: Re: Linker error with vendor library Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 20 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
