On 12/6/19 7:24 PM, Mark Rivers via Tech-talk wrote:
> Folks,
> I am trying to build the EPICS Xspress3 driver. It builds fine on Centos 7 with gcc 4.5
> On Ubuntu 18 with gcc 7.4 I get this error:
> /usr/bin/ld: /corvette/home/epics/devel/areaDetector-3-8/xspress3-2-2/lib/linux-x86_64-ub18/libimg_mod.a(img_mod_linux.o): relocation R_X86_64_32 against `.rodata' can not be used when making a PIE object; recompile with -fPIC
> /usr/bin/ld: final link failed: Nonrepresentable section on output
> collect2: error: ld returned 1 exit status
> /corvette/usr/local/epics-devel/base-7.0.3.1/configure/RULES_BUILD:212: recipe for target 'xspress3App' failed
> make[1]: *** [xspress3App] Error 1
> libimg_mod.a is a pre-built library provided by the vendor. Is there something I can change in the link options to avoid this error, or do we need to get a new library from the vendor?
You could try passing '-no-pie' when linking the xspress3App executable.
Having libimg_mod.a recompiled with -fPIC would probably be the desirable long term solution.
Running
> readelf -r libimg_mod.a |grep R_X86_64_32
might show something interesting, like whether the relocation
is referring to an internal name, or eg. something from libc
- Re: Linker error with vendor library Mark Rivers via Tech-talk
- Linker error with vendor library Mark Rivers via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
