1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Killing caRepeater on Windows 10
From: "Bommannavar, Arun S. via Tech-talk" <[email protected]>
To: "Bommannavar, Arun S." <[email protected]>, "Rivers, Mark L." <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Tue, 14 Jan 2020 16:00:38 +0000
To answer my own question…
Just starting MEDM doesn’t start caRepeater. But when I open a adl screen it shows up both in netstat and also under Task Manager Background Processess.
Dr. Arun Bommannavar
XSD, HPCAT, Sector 16
Argonne, IL 60439
TEL : (630) 252-0497
Email:     [email protected]
[The Maintainer's Motto]  →   If we can't fix it, it ain't broke.
From: Tech-talk <[email protected]> On Behalf Of Bommannavar, Arun S. via Tech-talk
Sent: Tuesday, January 14, 2020 6:32 AM
To: Rivers, Mark L. <[email protected]>
Does “netstat” show the UDP 5065 being used when caRepeater shows up in “tasklist” ?
Argonne, IL 60439
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Monday, January 13, 2020 5:53 PM
To: [email protected]
Subject: Killing caRepeater on Windows 10
Folks,
One of the hassles with Windows is that you cannot delete or replace an executable or dll if any process is using it.  If an EPICS client or IOC is run on Windows it will launch a caRepeater process that runs in the background.  If you want to update your EPICS installation you must kill that caRepeater process before you can do so.
In Windows 7 I found that the caRepeater process always showed up in Task Manager, so it was easy to find and kill.
In Windows 10, however, caRepeater does not show up in the Task Manager, even though it is running and the executable file cannot be deleted.
I found a couple of solutions to finding and killing caRepeater without rebooting.
1)      Use “tasklist” to find the PID of caRepeater
tasklist /FI "imagename eq caRepeater.exe"
will show the PID of caRepeater, which "taskkill" can then kill.
2) Microsoft has a nice "Process Explorer" application that is a more powerful version of Task Manager.  You can find it with Google and download it.
caRepeater shows up there, while it does not show up in Task Manager.  Note that in this case it is nested under PointGreyApp.exe, which is my IOC.
I suspect perhaps the reason it is not showing up in Task Manager is that Task Manager may only be showing nested processes 2 deep, rather than 3 deep?
CA_DISABLE_REPEATER Re: Killing caRepeater on Windows 10 Kasemir, Kay via Tech-talk
Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
RE: Killing caRepeater on Windows 10 Bommannavar, Arun S. via Tech-talk
Prev: RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Next: CA_DISABLE_REPEATER Re: Killing caRepeater on Windows 10 Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: Killing caRepeater on Windows 10 Bommannavar, Arun S. via Tech-talk
