1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Killing caRepeater on Windows 10
To: "'Engbretson, Mark S.'" <[email protected]>
Date: Tue, 14 Jan 2020 15:16:12 +0000
Ø  When I use caget, it appears both under Details *and* under Users on my Windows 10 system.
What version of caget are you using?
I just tested on my system with caget from base 7.0.3.1 and I don't see that.
Here I kill caRepeater, run caget, and then see that caRepeater is indeed running:
J:\epics\devel\dxp>taskkill /f /im caRepeater.exe
SUCCESS: The process "caRepeater.exe" with PID 9896 has been terminated.
J:\epics\devel\dxp>h:\epics\base-7.0.3.1\bin\windows-x64-static\caget 13IDA:m1
13IDA:m1                       -0.250184
J:\epics\devel\dxp>tasklist /fi "imagename eq caRepeater.exe"
Image Name                     PID Session Name        Session#    Mem Usage
caRepeater.exe                8576 Console                    1      3,640 K
When caRepeater is running this is what I see in Task Manager/Users and /Details.
I don’t see caRepeater in either screen.
It seems that either caget has changed behavior, or something is configured differently on your Windows 10 system from ours?
-----Original Message-----
Sent: Tuesday, January 14, 2020 8:26 AM
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Tuesday, January 14, 2020 6:20 AM
To: Žiga Oven <[email protected]>
Subject: Re: Killing caRepeater on Windows 10
> I believe that the other option to find this process in the Windows 10
> Task Manager is under the 'Details' tab (which to me looks like the
Windows 7 'Processes' tab) .
No, unfortunately that is where I expected to find it, but it does not appear there if caRepeater was started by another EPICS application.  It did appear in the Processes tab in Windows 7, but does not appear in the Details tab in Windows 10.
From: Tech-talk <[email protected]> on behalf of Žiga Oven via Tech-talk <[email protected]>
Sent: Tuesday, January 14, 2020 2:00 AM
To: [email protected]
Hi Mark,
I believe that the other option to find this process in the Windows 10 Task Manager is under the 'Details' tab (which to me looks like the Windows 7 'Processes' tab) .
Best regards,
Žiga
On 14. 01. 2020 00:52, Mark Rivers via Tech-talk wrote:
> Folks,
> One of the hassles with Windows is that you cannot delete or replace
> an
executable or dll if any process is using it.  If an EPICS client or IOC is run on Windows it will launch a caRepeater process that runs in the background.  If you want to update your EPICS installation you must kill that caRepeater process before you can do so.
> In Windows 7 I found that the caRepeater process always showed up in
> Task
Manager, so it was easy to find and kill.
> In Windows 10, however, caRepeater does not show up in the Task
> Manager,
even though it is running and the executable file cannot be deleted.
> I found a couple of solutions to finding and killing caRepeater
> without
rebooting.
> 1)      Use "tasklist" to find the PID of caRepeater
> tasklist /FI "imagename eq caRepeater.exe"
> will show the PID of caRepeater, which "taskkill" can then kill.
> 2) Microsoft has a nice "Process Explorer" application that is a more
powerful version of Task Manager.  You can find it with Google and download it.
> caRepeater shows up there, while it does not show up in Task Manager.
Note that in this case it is nested under PointGreyApp.exe, which is my IOC.
> [cid:[email protected]]
> I suspect perhaps the reason it is not showing up in Task Manager is
> that
Task Manager may only be showing nested processes 2 deep, rather than 3 deep?
> Mark
Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Re: Killing caRepeater on Windows 10 Žiga Oven via Tech-talk
Re: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Prev: Job opportunity at BESSY II - Berlin Nilson Pereira via Tech-talk
Next: RE: Killing caRepeater on Windows 10 Bommannavar, Arun S. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Next: Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
