1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: [EXTERNAL] Probelm with ethernet interface of Galil controller
From: Kathryn Baker - UKRI STFC via Tech-talk <[email protected]>
Date: Fri, 17 Jan 2020 15:37:16 +0000
We've ended up doing something similar here, our 20s are on private networks, our 40s have usually ended up on serial (via a Moxa) as even on private networks we weren't getting suitable behaviour. The downside to that is the way we use them we end up with a high memory usage on the serial ones.
On the network the Galil would get into an error state that could only be resolved by restarting it which isn't always easy given their physical locations.
I don't think we've tried a firewall yet, so can't comment on whether or not that helps, although I'm not sure what would have been broadcasting on the private VLAN consisting of a computer and Galils. But a serial connection via a Moxa seems to do enough that the systems are usable.
Kathryn
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Pearson, Matthew R. via Tech-talk
Sent: 17 January 2020 15:00
To: Heinz Junkes <[email protected]>
Subject: Re: [EXTERNAL] Probelm with ethernet interface of Galil controller
I’ve been seeing the same problem for years with the Galil DMC40x0 controllers. I have tried some of the ethernet tricks that the firmware supports (like the IK and IB commands), but nothing really worked. I did find that updating the firmware to a recent version (>1.2h) did help a lot on some systems, but didn’t solve it entirely. I was able to lock up a controller on one beamline just by starting an IOC. The only solution we have found that works long term is to put the controllers behind a firewall that blocks broadcast traffic, or isolating the controllers on a dedicated network port. If that’s not possible then I would recommend using a serial port via a Moxa.
Cheers,
Matt
Data Acquisition and Controls Engineer
Spallation Neutron Source
Oak Ridge National Lab
[Baker, Kathryn (STFC,RAL,ISIS)] <snipped the rest of the conversation from the reply>
Probelm with ethernet interface of Galil controller wangqisheng--- via Tech-talk
Re: Probelm with ethernet interface of Galil controller Heinz Junkes via Tech-talk
Re: [EXTERNAL] Probelm with ethernet interface of Galil controller Pearson, Matthew R. via Tech-talk
Prev: Re: [EXTERNAL] Probelm with ethernet interface of Galil controller Pearson, Matthew R. via Tech-talk
Next: Re: Open positions at ITER Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Re: [EXTERNAL] Probelm with ethernet interface of Galil controller wangqisheng--- via Tech-talk
